Thread: HVAC doesnt blow air any speed
Results 1 to 7 of 7
  1. #1 HVAC doesnt blow air any speed
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    98 gtp, dual climate sytem ( not the 3 knob) does not kick on at any speed, replaced the blower control power module and the blower motor, no operation yet. is there a relay? fuses are good as well as the ground, ALLData flow chart is telling me i have an open in the orange wire, what a nightmare
    COMP G
  2. #2 Re: HVAC doesnt blow air any speed
    SE Level Member 2001camaroB4C's Avatar
    What about the blower resistor?
    Or is that what you meant by the blower control power module? Or does the dual climate control not have one? Id think it still would, as far as I know the resistor just controls fan speed.
    http://wiki.answers.com/Q/How_to_tro..._Grand_Prix_SE I know i found a better how to then this once. Ill keep looking
    Blower motor resistor repair links: thanks to Blown97
    http://www.grandprixforums.net/f81/b...stor-6851.html (Blower Motor Resistor)
    http://www.grandprixforums.net/f81/t...stor-1350.html (The Old and The New, Blower Motor Resistor)
    Window deflector repair links: for why it could have gone bad.
    http://www.grandprixforums.net/water_floorboard.php
    http://www.grandprixforums.net/f73/w...-fix-6961.html (Water in floorboard (Take 2) - The Permanent Fix)
    2001 A4 Camaro B4C, 1.94 60ft - 8.48 1/8@84.13 - 13.17@104.29, should go faster with a better track and no ses light.
    And now a 98 Grand Prix
  3. #3 Re: HVAC doesnt blow air any speed
    GTX Level Member WhiteDevil's Avatar
    Aug 2008
    60118 NE Illinois
    id check the relay. same issue with every GM ive ever owned that stopped blowing any air, hot or cold( first car with AC so ive only done this on heater issues but its the same parts)
  4. #4 Re: HVAC doesnt blow air any speed
    Apr 2008
    Vallejo,Ca
    Quote Originally Posted by 2001camaroB4C View Post
    my car uses a blower motor control module, rather than a resistor pack like normal. the normal resistor is a 7 pin connector, where mine is 4 pin and whole lot more expensive lol. here is mine
    COMP G
  5. #5 Re: HVAC doesnt blow air any speed
    Apr 2008
    Vallejo,Ca
    Quote Originally Posted by WhiteDevil View Post
    where is the relay located? i cant find it in alldata
    nevermind. alldata says my car does noy use a relay , and relies on the blower motor control module
    also the relay is in the blower motor resistor of the manual HVAC units as well. so what are you talking about?
    COMP G
  6. #6 Re: HVAC doesnt blow air any speed
    Fayetteville, AR
    Im not real savvy with relays and electrical terms, but I had this similar problem in my old 02 GP. I went through the trouble and money of replacing the blower motor and all that like you have. It turned out to be the actual HVAC unit/box under the radio head unit, the part with the HVAC climate control and airflow direction knobs, that failed. Replaced it with a new dual climate control unit or whatever it's called, and worked just fine after that. Hope this helps! Good luck
  7. #7 Re: HVAC doesnt blow air any speed
    Apr 2008
    Vallejo,Ca
    Quote Originally Posted by Quicksilver_GP View Post
    did yours power up? mine acts like it works, i press the ac button and i can hear the ac clutch engage, however nothing comes out at any speed, hot or cold
    COMP G
  1. supercharger blow off valve?
    By 2story in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-17-2011, 06:24 PM
  2. Replies: 25
    Last Post: 09-01-2010, 05:49 AM
  3. blown 2 motors need help before i blow the 3rd
    By talonpower2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2008, 05:23 AM
  4. car sometimes starts/sometimes doesnt
    By 98gpgtp in forum General Tech Discussion
    Last Post: 11-05-2008, 12:29 AM
  5. Honda Blow up-a-thon
    By UR LOSN in forum Off Topic Discussion
    Last Post: 02-24-2008, 10:32 PM
