Thread: Power Steering issue
Results 1 to 6 of 6
  1. #1 Power Steering issue
    Feb 2010
    TN
    Power steering pump went dry don't know how long is been that way last time I checked it was sept (before you yell at me, you folks know what a PTA it is to get to that. Especially when the stb is right over it plus we been in single digit temps) its making a groaning noise should I just refill it or should I put some kind a sealer or something special in it.
  2. #2 Re: Power Steering issue
    A stop leak type fluid can work.
    Since it's been run dry you will likely get alot of air bubbles in the fluid. It's best to fill it some and run the car with the cap off and turn the wheel side to side, lock to lock to move the fluid around. Helps to have someone with a flash light watch the fluid, then top off as needed.
  3. #3 Re: Power Steering issue
    a funnel with a hose on the end of it works well for filling the pump. id look for a leak, something is wet under there.
  4. #4 Re: Power Steering issue
    Feb 2009
    flintnasty MI
    rack failure is very common... Look for leaks in the boots coming off the ends of the steering racks by the tie rods.
  5. #5 Re: Power Steering issue
    St. Louis
    If it's leaking somewhere besides the hoses, dump some Lucas power steering seal in it. Helped me get by for a while. Being cold as it is you may want to warm up the bottle of Lucas before you try pouring it into the PS pump as it's already pretty thick to begin with.
  6. #6 Re: Power Steering issue
    Banned
    Dec 2013
    Indiana
    Quote Originally Posted by FordMan77 View Post
    Ditto THIS ! Did the same thing and, so far so good........
  1. Power Steering Issue
    By cp93 in forum General Tech Discussion
    Last Post: 04-13-2012, 09:01 PM
  2. Power steering issue
    By izup69 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2011, 10:57 AM
  3. power steering issue
    By tstaller2005 in forum General Tech Discussion
    Last Post: 04-27-2011, 10:05 PM
  4. Power Steering Issue
    By dagger in forum General Tech Discussion
    Last Post: 11-13-2009, 09:06 PM
  5. Power Steering Issue?
    By streetsmart in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2009, 04:09 PM
