Thread: '05 Prix Heat Problems
Results 1 to 6 of 6
  1. #1 '05 Prix Heat Problems
    SE Level Member Breezy's Avatar
    Dec 2008
    Michigan
    Ok so just bought my car 3 months ago... it only has 35,000 miles... so I'm a little irritated to be fixing it already lol but it is what it is....
    Anyway.... my car seems to have this issue where the heat will be working then all of a sudden the air will start to get cold.... and the temperature guage starts rising..... it goes up for awhile and then it starts going back down.. and starts blowing warm air again. Works for awhile.... then does it again. Some days it seems to run in a cycle and some days it does this a couple times and then stops.
    I just had it to a mechanic today and my fluid levels are correct and there is nothing wrong with the thermostat. I am going to have to take it back but I was wondering if anyone has any ideas before I do so? I just paid to have one part fixed today; I really don't want to have to pay again for another estimate, have something fixed, and find out that it wasn't it....
  2. #2 Re: '05 Prix Heat Problems
    Maybe it has air in the system? I know that the old cars ,like in 70s and 80s you could get air in them and do the same thing yours is. It is just a thought.............Scott
  3. #3 Re: '05 Prix Heat Problems
    Dec 2008
    Michigan
    Quote Originally Posted by SG2000GTP View Post
    It's worth a try........ someone also suggested low coolant but I just had the oil changed before thanksgiving and they are supposed to check all that stuff.. or at least they say they do anyway...
    2005 Grand Prix... just standard... no fancy letters on the end. Nothing modified... yet. Maybe in the summer.
  4. #4 Re: '05 Prix Heat Problems
    PA
    Quote Originally Posted by Breezy View Post
    Don't trust that they did it. Just remove the radiator cap when the engine is cool and check to see if there is coolant all the way to the top of the radiator. Should only take about 30 seconds. If it is low, get a little pre-mixed coolant and add to it.
    And remember, you are checking the coolant in the radiator.
    2001 GSE
  5. #5 Re: '05 Prix Heat Problems
    Oklahoma
    When you say heat, you mean the interior cabin heat right? And when that turns cold, you see the coolant temp gauge on the dash go up, correct?
  6. #6 Re: '05 Prix Heat Problems
    Dec 2008
    Michigan
    Exactly. Sorry I should have been a little more specific.
  1. Air and heat problems
    By chrizzle17 in forum General Tech Discussion
    Last Post: 12-10-2008, 08:28 PM
  2. 98 Grand Prix GT too much heat NO AC
    By markh in forum General Tech Discussion
    Last Post: 09-25-2008, 10:29 PM
  3. Cut off heat shield?
    By kamper98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2008, 10:03 PM
  4. Heat shield with Plog?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-02-2008, 09:17 PM
  5. Heat Extractors
    By bula81069 in forum Visual/Body Modifications
    Last Post: 04-04-2008, 08:08 AM
