Thread: top swap, started engine, scans give me concern, help?.....
Results 1 to 13 of 13
Threaded View
  1. #7 Re: top swap, started engine, scans give me concern, help?.....
    Minnesota
    Well. I just so happen to live in Minnesota and have a top swapped 2002 Monte Carlo SS.
    Who did your tune? What bin did you use (Number)?
    When using a 2 bar MAP you have to change some things in the file otherwise it will read as NA.
    Did you change the injector settings for the L67 injectors?
  1. Engine doesn't rev when started
    By dave380 in forum General Tech Discussion
    Last Post: 03-25-2013, 11:45 AM
  2. Engine started to clank, took into shop, what should I do?
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-21-2012, 02:41 PM
  3. Started engine swap!
    By kyleinkman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2011, 12:45 AM
  4. Some of my Scans
    By Lawngoose in forum PCM Tuning
    Last Post: 10-13-2010, 07:37 PM
  5. uploading scans?
    By TheOtherNick in forum Off Topic Discussion
    Last Post: 09-28-2009, 12:19 AM
