Thread: Changed intake gaskets and now runs hot!
Results 1 to 5 of 5
  1. #1 Changed intake gaskets and now runs hot!
    Jan 2014
    capac, MI
    Okay..Here is my third post for this project! You guys have been a great help!!
    I finished the Intake gasket challenge and now am trying to burp out the air in the coolant system. When I had the intakes off I vacuumed out all the coolant in the heads so there is likely a lot of air int he system. Car started up great and is running good, but now its running quite hot. I have been trying to burp the coolant system but can't seem to get the air out. Open the bleeder and steam comes out, then a little sputter of coolant, and then steam. Steam, steam, steam. Then the temp gage started rising so I had to abort mission. Any suggestions? I have been bleeding it for a while now, and it should not take that long.
    Help!!
  2. #2 Re: Changed intake gaskets and now runs hot!
    remove the t stat housing, and t stat then fill the lim with coolant from the hole in the manifold. that way theres no question the block is full of coolant.
  3. #3 Re: Changed intake gaskets and now runs hot!
    ^^this is the best way to do it
  4. #4 Re: Changed intake gaskets and now runs hot!
    Jan 2014
    capac, MI
    I got it! Thanks for the help! This is by far one of the better repair forums I belong to! Quick responses lead to quick fixes! Car is running great! More coolant and a little patience did the deal. Now I have hot heat and a cool motor!
  5. #5 Re: Changed intake gaskets and now runs hot!
    awesome.
  1. Intake Gaskets
    By Huckleberry in forum Engine
    Last Post: 12-09-2013, 11:35 AM
  2. Replies: 5
    Last Post: 04-15-2013, 03:07 PM
  3. Changed plugs now runs like .....
    By toolmanz in forum 5.3L V8 (LS4)
    Last Post: 07-27-2012, 07:27 AM
  4. Changed lower intake manifold gasket and valve cover gaskets
    By grn97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2011, 08:19 PM
  5. Runs 5 minutes...Stalls...Changed everything
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-09-2009, 02:47 PM
