First day got the engine out, got the PLOG on, new crankshaft cover gasket. Broke some vacuum lines, and vacuum manifold piece as well as boost bypass valve. All plastic welded back together, should hopefully hold. New coolant elbows on, water pump replaced. Tomorrow hopefully replace supercharger coupler and oil, oil pan gasket, VC gaskets, driver CV axle, both LCA's, and rack and pinion. Who knows about getting the engine back in. Maybe by monday.
