Thread: Need Help window wont roll up or down.
Results 1 to 6 of 6
  1. #1 Need Help window wont roll up or down.
    Jan 2014
    Bay Area CA
    So the switch works the motor works. I can hear it trying to raise and lower the driver side window. It is like it is off the track. I cannot manually pull it up more than a quarter of the way. Pulled door panel and am unsure of where to go from here.
  2. #2 Re: Need Help window wont roll up or down.
    you need a new window regulator. the cable is shot.
    ive opened up the door and stuck a cut to size 2x4 under the window to hole it up for security in my truck when it broke on me.
  3. #3 Re: Need Help window wont roll up or down.
    Jan 2014
    Bay Area CA
    How do I replace the cable? PArt Number? And thanks for the quick reply.
  4. #4 Re: Need Help window wont roll up or down.
    you dont replace the cable, you buy a "window regulator" for said door. its a new motor cable and track. its like a 3 bolt job to change.
  5. #5 Re: Need Help window wont roll up or down.
    Jan 2014
    Bay Area CA
    Fixed it thanks for the help.
  6. #6 Re: Need Help window wont roll up or down.
    Arizona
    I had both my rear windows go out and it costs about $90 a window. 30 to 45 minutes tops to replace.
  1. Replies: 0
    Last Post: 05-05-2013, 05:05 PM
  2. window wont roll up!
    By natethegreat in forum General Tech Discussion
    Last Post: 01-31-2012, 05:37 PM
  3. window won't Roll up
    By Austin2000SE in forum General Tech Discussion
    Last Post: 12-02-2011, 11:21 AM
  4. rear window wont roll up or down? help
    By 04gtgp in forum 04+ Specifics
    Last Post: 11-07-2011, 06:12 PM
  5. Windows Wont Roll Up or Down
    By MustangMatt96GT in forum General Tech Discussion
    Last Post: 07-11-2011, 06:16 PM
