Thread: Car bouncing like fun in the back seat?
Results 1 to 20 of 20
  1. #1 Car bouncing like fun in the back seat?
    Jun 2012
    Ontario Canada
    So at around 10-15km/h the car does this weird wobble thing, kind of like if you were to bounce up and down in the drivers seat the car would rock back and forth, or more commonly if you're doing things in the back seat. It does t again around 55km/h (but a lot faster) and then again somewhere around 90-100km/h.
    I've recently done front wheel bearings, tie rods (both ends), breaks and rotors, when it does this. The steering wheel doesn't move at all and you can't feel it through the steering wheel.
    Known issues: Rear passenger side makes clicking noise when you push car side to side at the back (possible strut wall or strut itself?)
    anybody have any ideas?
  2. #2 Re: Car bouncing like fun in the back seat?
    rotate the tires back to front, see if the bound moves. if so its your tire.
    while it jacked up lugs tight do all the push and pull tests to feel for any play. nothing should move back there. only thr wheel should spin.
  3. #3 Re: Car bouncing like fun in the back seat?
    Jun 2012
    Ontario Canada
    Think it's a shifted belt in a tire? Also today might be the day to do the push/pull test as it's supposed to be 7 degrees (Celsius that is), will report back
  4. #4 Re: Car bouncing like fun in the back seat?
    the tire could have a lump in it, or the side wall, or just so low on tread its egging out. or the wheel is bent maybe. or loose lug nuts. wont know till you check it all out.
  5. #5 Re: Car bouncing like fun in the back seat?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Mine did a side to side motion when a belt shifted/broke in my tire but that tire was on the wear bar old and cracking
    Sent from my HTC Thunderbolt using Tapatalk
    2012 F150 STX
    - Gonna be a race truck
  6. #6 Re: Car bouncing like fun in the back seat?
    Jun 2012
    Ontario Canada
    good news is, tires are fine!r
    bad news,
    jack falls out from under car, use spare tire jack to lift car up to slide other jack back under, set under sway bar,
    jack up enough to use spare jack to get other jack on the suspension, pump one more time, sway bar breaks
    back to good news
    getting new sway bar/inner tie rod ends
    I just did my tie rod ends ~6 months ago, forgot to put plastic boots back around outside of the inner tie rod ends, now they're shot.
  7. #7 Re: Car bouncing like fun in the back seat?
    Apr 2012
    Dayton, OH
    If you Jack up the back I use the rear crossmember thingy its near the y in the exhaust
    2012 F150 STX
  8. #8 Re: Car bouncing like fun in the back seat?
    Jun 2012
    Ontario Canada
    sweet, and i also like to imagine my ps is a supercharger! hahaha.
    The factory jack point was rusted so it slipped
  9. #9 Re: Car bouncing like fun in the back seat?
    yeah, dont jack on the sway bar, even if you think thats what your jacking on, its high up, no way you jacked it up on that. you'll bend stuff like that.
    jack from the frame back there.
  10. #10 Re: Car bouncing like fun in the back seat?
    Jun 2012
    Ontario Canada
    It was the front end, and the jack slipped out so the brake rotor was ~ 0.25 inches off the ground, the sway bar was the highest point i could slide my jack under, broke it in the front
  11. #11 Re: Car bouncing like fun in the back seat?
    Apr 2012
    Dayton, OH
    Oh on the front I use the subframe thing
    2012 F150 STX
  12. #12 Re: Car bouncing like fun in the back seat?
    if you have a floor jack put it over the frame bushing and jack it up. or a bottle jack also works.
    the back see where the bottle jack is, just past it is the rear trailing arm, where it bolts to the under side of the cars body, theres a some frame, jack from there if the rockers are rotted out.
  13. #13 Re: Car bouncing like fun in the back seat?
    Jun 2012
    Ontario Canada
    thanks for the info, the first pic is where i used after i picked the car up a bit with the swaybar, but unfortunately the damage was done
  14. #14 Re: Car bouncing like fun in the back seat?
    i see now front sway bar, hope the cap didnt bend on ya. if a new front end clunk starts its the sway bushing. like mine, all shot in that pic lol
  15. #15 Re: Car bouncing like fun in the back seat?
    Jun 2012
    Ontario Canada
    she didn't that's where it snapped right before it, surprisingly
  16. #16 Re: Car bouncing like fun in the back seat?
    Apr 2012
    Dayton, OH
    Not to thread Jack but if you don't jack on the bushing can it damage it?
    2012 F150 STX
  17. #17 Re: Car bouncing like fun in the back seat?
    ive jacked right on the bolt head, and the floor jack cup fits over the bushing, no damage yet that i can see or feel. but its never gonna slide off the jack is it? thats my main reson for jack from there.
  18. #18 Re: Car bouncing like fun in the back seat?
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Get some jack stands yall...be safe!
  19. #19 Re: Car bouncing like fun in the back seat?
    in my pic there i was either rotating the tires or doing a brake job. i dont use a jack stand unless im going under the car.
  20. #20 Re: Car bouncing like fun in the back seat?
    Jun 2012
    Ontario Canada
    update friends,
    $200 got me a new sway bar kit, and a new tie rod end
    feels tight as a drum
    thanks all
  1. INFORMATION Do You Know What's Living Under YOUR Back Seat??
    By 2dee11 in forum Detailing Tips and Tricks
    Last Post: 08-26-2013, 10:12 AM
  2. 08 gp holes under back seat
    By Bryant in forum 04+ Specifics
    Last Post: 04-19-2013, 08:03 PM
  3. Back seat in 1998 gtp
    By Xereck in forum Audio, Security & Visual Electronics
    Last Post: 01-13-2012, 04:17 PM
  4. how do you remove the back seat?
    By 2000GTP in forum General Tech Discussion
    Last Post: 10-26-2008, 08:11 PM
  5. Rust behind and under back seat
    By 03GPScottyd in forum Visual/Body Modifications
    Last Post: 01-04-2008, 03:36 PM
