Thread: Swapped to 3.4 pulley now there's a belt squeak...
Results 1 to 20 of 22
  1. #1 Swapped to 3.4 pulley now there's a belt squeak...
    GT Level Member K Kraziee's Avatar
    Apr 2013
    Milwaukee
    I just recently changed my pulley to a 3.4, there wasn't a squeak the first day but by day 2 it started chirping. I have the 658 belt on. Should I try the stock belt? Thanks
    DD: 2000 Pontiac Grand Prix GTP
    3.5 ZZP MPS, HAI, ZZP Ported Throttle Body, PLOG, 3" Catless DP, Water pump and Alt. UD Pulley, Custom Tune
  2. #2 Re: Swapped to 3.4 pulley now there's a belt squeak...
    Dec 2010
    DMV
    Stock belt wouldn't fit, check your pullies.
    Sent from my HTC One using Tapatalk
  3. #3 Re: Swapped to 3.4 pulley now there's a belt squeak...
    Florida
    Stock belt would be too long.
    Start the car, and watch the belt from straight down and see if there's any side to side wobble. If so, check all your pullies.
    Now, I just cammed my car recently, didn't change pullies or belts. When I put it back on, it was chirping. I watched it, no wobble. Removed it a few times trying to find something.
    I finally just put 1 small spritz of belt dressing, and it's been fine since (about 2-3weeks)
  4. #4 Re: Swapped to 3.4 pulley now there's a belt squeak...
    Apr 2013
    Milwaukee
    Ok, I'll check out the pulleys tomorrow.
    Sent from my PantechP8010 using Tapatalk
  5. #5 Re: Swapped to 3.4 pulley now there's a belt squeak...
    Antioch, IL
    I run stock belt on 3.4 with no problems....
    2009 Challenger SRT8
    Expert at being gay.
  6. #6 Re: Swapped to 3.4 pulley now there's a belt squeak...
    GTP Level Member rodguezsciii's Avatar
    Sep 2012
    stock belt on my 3.6 was crazy loud....squeezed a Gatorback 660, chirp went away....
  7. #7 Re: Swapped to 3.4 pulley now there's a belt squeak...
    Apr 2013
    Milwaukee
    You would think the stock belt would make it chirp much more since it's much longer. For some reason though it was a pita getting the 658 on.
  8. #8 Re: Swapped to 3.4 pulley now there's a belt squeak...
    Jan 2012
    Philadelphia
    I been running a stock belt on my 3.4 setup for well over a year now with no problems, it doesn't make noise, slip or anything. One thing I had problems with in the past is when putting the s/c belt back on if its not wrapped all the way around the harmonic balancer at the bottom where its hard to see it will jump off one rib on the h/b and will squeak.
  9. #9 Re: Swapped to 3.4 pulley now there's a belt squeak...
    Apr 2013
    Milwaukee
    Is that the big pulley at the bottom? I thought that was the crank pulley?
  10. #10 Re: Swapped to 3.4 pulley now there's a belt squeak...
    Jan 2012
    Philadelphia
    Yea same **** lol
  11. #11 Re: Swapped to 3.4 pulley now there's a belt squeak...
    Apr 2013
    Milwaukee
    Alright lol
  12. #12 Re: Swapped to 3.4 pulley now there's a belt squeak...
    GTP Level Member AjL227's Avatar
    IL
    IIRC, you can put on a 3.0" idler pulley and run the stock belt with a 3.4"
    I installed an I/C before I put on a 3.4", so I had a longer belt.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  13. #13 Re: Swapped to 3.4 pulley now there's a belt squeak...
    Apr 2013
    Milwaukee
    Are tensioner pulleys known to go bad after a pulley swap? I looked at the crank pulley and the belt seemed a tad off to the outside of the pulley, towards the passenger side. I tried pushing it towards the other side and it was definitely off of a rib on the outside of the pulley. Is it supposed to look like it's sort of more at the edge of the outside? I can't figure this out. I'll try belt dressing tomorrow but I'm afraid it might make it worse.
  14. #14 Re: Swapped to 3.4 pulley now there's a belt squeak...
    Sep 2012
    Quote Originally Posted by K Kraziee View Post
    I changed every pulley and even the tensioner assembly when I went down to a 3.6 just for maintenance reasons....and alignment issues could be caused by how far back or forward your MPS hub sits....
  15. #15 Re: Swapped to 3.4 pulley now there's a belt squeak...
    Apr 2013
    Milwaukee
    Ok, I just have a press on pulley. I didn't go with the mps. My pulley isn't all the way flush with the snout, it's very close, but not all the way.
  16. #16 Re: Swapped to 3.4 pulley now there's a belt squeak...
    Got a pic?
  17. #17 Re: Swapped to 3.4 pulley now there's a belt squeak...
    Apr 2013
    Milwaukee
    Not at the moment. I can get one a little later though.
  18. #18 Re: Swapped to 3.4 pulley now there's a belt squeak...
    Apr 2013
    Milwaukee
    Purchased both idler pulley's and tensioner assembly from rock auto so I'll see if that helps. My tensioner assembly was wobbling a bit so I think somehow it got misaligned and messed up the springs. Here's a pic of my sc pulley.
  19. #19 Re: Swapped to 3.4 pulley now there's a belt squeak...
    Need a pic of the end of it to see how far on the snout shaft it is. Check your hb and make sure it's over all the way on it. Mine used to chirp when the belt was over one rib to far to the passenger side.
  20. #20 Re: Swapped to 3.4 pulley now there's a belt squeak...
    Apr 2013
    Milwaukee
    Ok so I figured out its coming from the supercharger Pulley. It seems to be spinning straight. What would cause this?
  1. pulley/belt squeak
    By ws6dreamer in forum Introductions/Noob Questions
    Last Post: 04-27-2013, 11:32 PM
  2. Alternator Pulley Squeak
    By Adidasdude1989 in forum General Tech Discussion
    Last Post: 06-17-2012, 08:39 AM
  3. Pulley Squeak
    By Adidasdude1989 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-03-2012, 07:25 AM
  4. Perpetual belt squeak
    By Coogles in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-23-2008, 09:07 AM
  5. 3.4 pulley squeak
    By pacoflyer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-28-2008, 12:15 PM
