Thread: HUD Install
Results 1 to 8 of 8
  1. #1 HUD Install
    Sep 2012
    Cedar Rapids, Iowa
    I'm looking for someone who has done an HUD install in a car that doesn't have one. I took out my gauge cluster and lucky me I have the wire harness for it sitting back there as some Grand Prixs do (even ones that don't have an HUD). So I know I could hook it up and cut out a piece of my dash trim for it, my only concern is there doesn't appear to be a place to set the HUD unit and keep it stable, will the gauge cluster hold it in place or what?
  2. #2 Re: HUD Install
    there should be the part where you bolt it fast i believe. I have all the hud parts you would need if you're interested.
  3. #3 Re: HUD Install
    Sep 2012
    Cedar Rapids, Iowa
    I actually forgot that I had bought the upper trim a while back. How much for the HUD and the switch. I would need at least a small amount of wires sticking out of the back of the switch.
  4. #4 Re: HUD Install
    hud and switch I'd let go for $40 shipped. You probably have the switch wiring as well though. I have the pigtail for it though if you need it.
  5. #5 Re: HUD Install
    Sep 2012
    Cedar Rapids, Iowa
    Yes I would like the pigtail and that sounds fine. Does the HUD need to be hooked up to the DIC?
  6. #6 Re: HUD Install
    i don't think so
  7. #7 Re: HUD Install
    Dec 2008
    Lawndale, CA
  8. #8 Re: HUD Install
    Sep 2012
    Cedar Rapids, Iowa
    Quote Originally Posted by The Guz View Post
    Perfect! Thank you! I tried using the search function on the forum but couldn't quite find it
  1. Help with Install
    By CSlater21 in forum Audio, Security & Visual Electronics
    Last Post: 03-21-2012, 06:52 PM
  2. Z7 Install help
    By ARFF22 in forum Turbo
    Last Post: 02-01-2011, 01:35 AM
  3. big install
    By BoostJunki3 in forum Audio, Security & Visual Electronics
    Last Post: 12-30-2009, 12:25 AM
  4. Hv3 install help
    By PWNED in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-24-2009, 04:00 PM
  5. HUD Install
    By Rather B Blown in forum General Tech Discussion
    Last Post: 11-12-2009, 11:12 AM
