Thread: blower motor/heat problem help!
Results 1 to 5 of 5
  1. #1 blower motor/heat problem help!
    Jun 2013
    detroit
    i have an 06 gp and after a cold day i turned on the heat and blower motor wasnt working. the problem isnt the blower motor though. i had this problem about a month ago and replaced something and i forgot what it was. no matter what speed or where it is directed no air blowing. it does produce hot heat it just doesnt blow it out. help!
  2. #2 Re: blower motor/heat problem help!
    Feb 2010
    TN
    Sounds like a blend door
  3. #3 Re: blower motor/heat problem help!
    SE Level Member beefgravy's Avatar
    Jan 2014
    grand rapids michigan
    That would be the blower motor resistor.
  4. #4 Re: blower motor/heat problem help!
    Sep 2012
    Cedar Rapids, Iowa
    I have the exact same problem. Works fine with the A/C just not with heat but still produces heat
  5. #5 Re: blower motor/heat problem help!
    GT Level Member RivMan's Avatar
    Oct 2012
    Pinckney, MI
    I just had to replace the Blower Motor Resistor on my 04. I also had a bad connection at the power wire feeding the heater. If you pull the radio out, there is a junction connector behind it. Disconnect that connector, and see if any of the pins are burnt. The +12 pin on mine was burnt and not making a solid connection.
    -Rob
    2004 GPGT - L32 Swap, CompG Trans - Click Here!
    1999 Regal - 300k miles: SOLD!
    1995 Riviera - L67 Swap, 12.9@107: SOLD!
    1999 GTP - 12.9@104: SOLD!
  1. hello- have intermittent heat/ac blower problem.
    By jmsgtp04 in forum Introductions/Noob Questions
    Last Post: 08-28-2013, 10:52 PM
  2. blower motor problem/question
    By thebandit343 in forum General Tech Discussion
    Last Post: 03-10-2013, 07:16 PM
  3. Replies: 3
    Last Post: 03-01-2013, 08:37 PM
  4. Replies: 30
    Last Post: 12-12-2012, 04:35 PM
  5. Help! No heat, blower motor issue???
    By lks28 in forum General Tech Discussion
    Last Post: 11-21-2012, 11:19 AM
