Thread: Heated Seat male connector location? 97-03
Results 1 to 9 of 9
Threaded View
  1. #1 Heated Seat male connector location? 97-03
    Oct 2013
    Toronto
    Putting Leather heated seats in my 1999 gtp. got a set from 2000gtp.(i dont mind the 97-03 seats) So doing the wiring hook ups
    I took the heated switches plate and seats from doner car. I'll eventully get another driver heated seat and retrofit to a pasenger seat as well but thats for a later time.
    I have went through every how to write up on heated seats and have not found the answer to where the main harness connector is for heated switch that is in my gtp.most write ups are going to 04+ seats and up iam staying with the 97-03 seats
    I took the center console out and found a main connector hanging up top left side with a metal clip with 10 wires in it traced alll the wires and they go to shift release connector light for PRND321. all the factory wires seem to be going to correct locations. no separate wires for switch.
    Question is would the heated switch male side seperate connector be found behing the hvac radio controls???? further up the main harness.
    Found my car has the 15amp fuse in for the lumbar/heat seats.
    Under my driver seat i have all wires pink,blue,black,black white tracer ,and 2 orange coming from main harness with only the with only my cloth seats using the 2 orange, black.black white tracer. so it looks like my car has all the wiring in place with connector its just iam not finding the heat switch connector around the center console area.
    What gets me is my stock connector under the seat has the pink and blue wires which means it has to be somewhere in main harness.
    thanks for any help
  1. Rear O2 sensor connector location
    By Gasnmyveins in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-04-2013, 06:57 AM
  2. Full size female antenna to mini male antenna adaper?
    By iowagtp in forum Audio, Security & Visual Electronics
    Last Post: 11-09-2012, 02:52 PM
  3. 97 to 05 seat connector
    By Logan541 in forum General Tech Discussion
    Last Post: 08-08-2012, 02:00 PM
