Thread: Car died while driving! NO POWER
Results 1 to 9 of 9
  1. #1 Car died while driving! NO POWER
    SE Level Member Mellsthatguy's Avatar
    Dec 2012
    Michigan
    I have an 2000 GP and after getting a jump start the car turned off twice while on my way home. The first time the car turned off the dashboard was still on and the battery light was on so I just pulled over and started the car back up with no problem. The second time the car turned off and the dashboard was on for a few seconds and when then car completely stopped there was no power at all. The key is still in the ON position and i can not remove it. I have changed the battery and still nothing. I have checked all fuses and still nothing.
  2. #2 Re: Car died while driving! NO POWER
    Dec 2010
    DMV
    Possibly the alternator is dead, you can have it checked at AutoZone. As far as the key there is a hole under the steering wheel that can be pushed to remove the key. Use a screwdriver and insert it into the hole and remove the key.
    Sent from my HTC One using Tapatalk
  3. #3 Re: Car died while driving! NO POWER
    Dec 2012
    Where 4T65E's were born
    Does anything work? Door lights or interior lights?
    Sold.
  4. #4 Re: Car died while driving! NO POWER
    Have the battery and alternator tested at the parts store. Also make sure your battery/ground cables are good and free of any corrosion.
    04 Comp G.
  5. #5 Re: Car died while driving! NO POWER
    when it just stalls did the tach drop to zero? if so your crank sensor is dead. has nothing to do with the battery issue tho. get the bat and alt tested.
    the key wont turn back and come out if the battery is dead. you then need to push the button in under the column. or hook jumper cables up to power the car. then it will turn back.
  6. #6 Re: Car died while driving! NO POWER
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    Scotty a guy told me my 3100 has 2 crankshaft sensors. Does that sound right ?
  7. #7 Re: Car died while driving! NO POWER
    i dont know much about the 3100 or 3400. its very possible tho. or its the cam and crank they are talking about.
  8. #8 Re: Car died while driving! NO POWER
    Sep 2013
    tulsa okla
    thanks man . Knew I should have bought a Ford. lol
  9. #9 Re: Car died while driving! NO POWER
    It's not a sensor. You have an issue with your battery or a ground. Try wiggling the battery cables with the headlights turned on and see if you can make them turn on by wiggling it.
  1. Loss of power while driving
    By Josiahsgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-24-2013, 09:19 PM
  2. Car died while driving and oil light came on.
    By Wotgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-16-2012, 09:18 AM
  3. Driving with a bad power steering pump
    By Chad Gervais in forum General Grand Prix Discussion
    Last Post: 08-25-2012, 01:16 AM
  4. Losing power driving down the road
    By YeahRight in forum General Tech Discussion
    Last Post: 11-11-2011, 05:56 PM
  5. Couple Problems. Car died while driving and noise from S/C
    By BonesSS in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-28-2010, 11:13 PM
