when it just stalls did the tach drop to zero? if so your crank sensor is dead. has nothing to do with the battery issue tho. get the bat and alt tested.
the key wont turn back and come out if the battery is dead. you then need to push the button in under the column. or hook jumper cables up to power the car. then it will turn back.
