The easiest way to get the stock one out that I have found is to put the assembly in a vise and drive a sharp gasket scraper through the two solid portions of the mount along the aluminum center. I just used a few blows from a dead blow mallet to drive it through the rubber. Once both sides are cut, the aluminum center will pop right out. Then the remaining outer piece of rubber can be easily pryed out of the assembly with a screwdriver.
I did the exact same with mine, works great and easy too!
