Thread: HVAC Issue. Cant switch between any of the vents for heat
Results 1 to 13 of 13
  1. #1 HVAC Issue. Cant switch between any of the vents for heat
    Oct 2012
    Canada
    Hey guys,
    So starting today i cant switch between all the vents in the car (1999 GTP). I tried turning the heat on and off about 8 times but that did nothing. It still sounds like its blowing strong and still nice and warm, i just cant switch it between defrost or the floor or even the dashboard vents.
    What could be the issue here?
  2. #2 Re: HVAC Issue. Cant switch between any of the vents for heat
    theres a vac line on the top of the super charger, it leads to the fire wall then down the fender to the fuse box where it them joins a loom of wires and enters the cab of the car. check this line for cracks or leaks. it powers the vent directions.
  3. #3 Re: HVAC Issue. Cant switch between any of the vents for heat
    Oct 2012
    Canada
    Alright i will take a look, thanks!
  4. #4 Re: HVAC Issue. Cant switch between any of the vents for heat
    Oct 2012
    Canada
    I took a look at that vacuum line and it looks like its ok to me
  5. #5 Re: HVAC Issue. Cant switch between any of the vents for heat
    Oct 2012
    Canada
    I should also mention its the dual digital climate control that i have in my car.
  6. #6 Re: HVAC Issue. Cant switch between any of the vents for heat
    still vacuum powered.
  7. #7 Re: HVAC Issue. Cant switch between any of the vents for heat
    Oct 2012
    Canada
    So more than likely i still have a vacuum issue? il have to get a mechanic to look at it then.
    Is there anything else i should test to make sure its a vacuum issue? like cruise control?
  8. #8 Re: HVAC Issue. Cant switch between any of the vents for heat
    you can check that your self easy. if that line is cracked the vents wont change direction.
    or the climate control head unit in the dash took a dump.
    the vac line is a free check, and would cost less then a buck to fix most of the time.
  9. #9 Re: HVAC Issue. Cant switch between any of the vents for heat
    Oct 2012
    Canada
    Is it common for the control head unit to go for a ****? cause that line to my eyes looked fine.... but im a computer guy... not a car guy, lol
    Edit: I'll turn the car on and see if i can hear any leaks. Should i turn the heating system on and then listen? or should i hear a vacuum leak without the heating system on?
  10. #10 Re: HVAC Issue. Cant switch between any of the vents for heat
    that line under the hood runs to a box behind the dash then to the vac pumps that move the vent controls levers. so you may hear a hiss under the dash if one of the inside car line broke, or the vac pump its self.
    ive seen on the board here where the unit does go bad, then others who changed it and still didnt get it to work.
    these levers are plastic under the dash, they break all by themselves sometimes. so if you open up the dash some you can see if the vac pumps are moving, if they are the lever arms snapped.
    this how to is for the blend door actuators, but the vac pumps are right there next to them, its the round part in the lower right of the first pic. theres one on the pass side as well, removing the glove box door gives you full view of that side.
    http://www.grandprixforums.net/showt...door+actuators
  11. #11 Re: HVAC Issue. Cant switch between any of the vents for heat
    Oct 2012
    Canada
    So now its working again.... I drove home from work and it was working no problem. I even stopped and restarted the car again as a test and it was fine. What could be going on then?
  12. #12 Re: HVAC Issue. Cant switch between any of the vents for heat
    could be the climate control's buttons are dying or its broken inside, you hit a bump and it works now, hard to say.
  13. #13 Re: HVAC Issue. Cant switch between any of the vents for heat
    Oct 2012
    Canada
    Well I'll keep an eye on it I guess. I do have a different issue though. Every now and then my air bag light comes on for up to 5 min (sometimes less) then goes away. Started at about the same time as my vent select issue.
  1. A/C & Heat Vents Issue? 99 GT
    By corxbeans in forum General Grand Prix Discussion
    Last Post: 06-17-2013, 10:45 PM
  2. HVAC vents not changing
    By Jakegday in forum General Tech Discussion
    Last Post: 05-28-2013, 06:12 AM
  3. Vents issue
    By Camambro in forum General Tech Discussion
    Last Post: 09-24-2012, 02:59 PM
  4. No heat from driver side vents!!!!!!
    By Blown38 in forum General Tech Discussion
    Last Post: 01-31-2010, 05:09 PM
  5. Low Air Flow on Heat HVAC
    By scootcoupe91 in forum General Tech Discussion
    Last Post: 12-12-2009, 06:41 PM
