Thread: Shut off while driving.
Results 1 to 14 of 14
  1. #1 Shut off while driving.
    Jun 2012
    Southern NJ
    Was driving along, getting on it a little bit maybe 75% throttle, and then it just cuts out with a nice little backfire (I'm assuming from it having cut out at like 4 grand) and then that was it. Tried to go and put some gas in it thinking the gauge might be wrong, but it just turns over. Didn't sound mechanical like I snapped the chain or dropped a rod or anything.
    At this point I don't have any ideas. Where do I start?
  2. #2 Re: Shut off while driving.
    Dec 2012
    Where 4T65E's were born
    Well one likely thing to cause that is the crank sensor. There are many others but this is the easiest place to start. Do the rpm's go to 200 or so when cranking? It should. Next your fuel pump may have just died. Do you have fuel pressure? press the schrader valve on the rail and see if fuel squirts out.
    Sold.
  3. #3 Re: Shut off while driving.
    Jun 2012
    Southern NJ
    Didn't check the RPM when cranking, car is down the street. Once I get it pulled back here I'll check for fuel pressure.
  4. #4 Re: Shut off while driving.
    Jun 2012
    Southern NJ
    Just got her home. Cranked it, and nothing.. tach read flat 0 and my scangauge did, too. Crank position sensor?
  5. #5 Re: Shut off while driving.
    Dec 2012
    Yeah it's a good bet. They usually start working once it cols off temporarily, but I guess some can just flat out stop working. Like my starter, most you can hit them and get them to work for a while, but mine left me stranded with hitting it doing nothing.
    To be sure its not the computer or the wiring you can unplug the connector and hook an led up and see if it flashes when you crank it, but it's probably the sensor anyway.
    Sold.
  6. #6 Re: Shut off while driving.
    Jun 2012
    Southern NJ
    Went outside today and cranked the GTP, and it fired right up. Still likely for CKP?
  7. #7 Re: Shut off while driving.
    Dec 2012
    When they go bad, they will almost always be intermittent (like I said before) so the crank sensor is still the likely cause. Now that it's working, does the tach go to 200 when cranking? It might start too quick to tell though.
    Sold.
  8. #8 Re: Shut off while driving.
    Jun 2012
    Southern NJ
    Unfortunately, my car is too healthy and she starts on the first crank, so I can't really tell.
  9. #9 Re: Shut off while driving.
    GT Level Member Exile's Avatar
    Chicago
    My car stalled several times while I was driving due to bad CPS. I think there was up to a week between stalls even. My tach would also just stop giving a reading sometimes while cruising and go to 0 until I stopped and restarted the car. Replaced it with a ~$34 CPS off amazon and was fixed!
  10. #10 Re: Shut off while driving.
    Dec 2012
    Well I was just wondering because it could be a way to show you what I mean. Doesn't matter though. I bet it's the cps
    Here's an example of the tach going to 200 on a cold morning it took a bit to start. Usually it starts quickly and I don't see it. But as a reference:
    Sold.
  11. #11 Re: Shut off while driving.
    Jun 2012
    Southern NJ
    I can leave mine for weeks in the freezing cold and it starts up like I had it running an hour ago. Ever since I rebuilt the top end it's been super reliable and stupid fast. This has been my only major issue. That said, I've got a new CKP sitting on my desk and I'm going to swap it in this weekend.
  12. #12 Re: Shut off while driving.
    Dec 2012
    Right, the sensor just transmits crankshaft speed and position. It doesn't affect how well it runs, just whether it does or doesn't. Good luck with the install. The video was from a few weeks period I was having an extended cranking time due to a possibly bad fuel pressure regulator. It's back to starting in a normal amount of time.
    Sold.
  13. #13 Re: Shut off while driving.
    Jun 2012
    Southern NJ
    Yep, I'm well aware of what the sensor does. I'm just surprised it went out on me.
  14. #14 Re: Shut off while driving.
    Dec 2012
    Well..don't be lol. It's a common 3800 thing, well many GM platforms for that matter. I'm going to change mine as a precaution because I know it will go bad eventually, and leave me stranded somewhere.
    Sold.
  1. Please Help! 2007 GT 3800 Supercharged shut itself off while driving on hiway...
    By shelovesher GT in forum Introductions/Noob Questions
    Last Post: 03-26-2013, 12:34 AM
  2. 05 G.P. shut down
    By cclan64 in forum General Tech Discussion
    Last Post: 11-27-2012, 06:31 PM
  3. 2004 grand Prix shut off while driving
    By Roman in forum General Tech Discussion
    Last Post: 10-24-2011, 09:59 AM
  4. shut off while driving
    By WOTFTW in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-22-2011, 11:31 AM
  5. engine shut off while driving
    By farmer in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-22-2011, 08:45 AM
