Ok, so I seem to have the fairly common park into reverse thunk on my 99 GTP (207K). I'm hoping it's the top mounts since those are easy to fix, but I'm not sure. I did check the bottom mount through the driver's wheel and it looks good - no coated in leaking fluid at least. I can't tell if changing the dogbone would actually help - it does move around alot on the other end, I know some people rotate those to stiffen it up, not sure it's my preferred solution maybe it's the best one? Not sure how much movement is supposed to be there. Should I pull the bolt and check the other end?
https://www.youtube.com/watch?v=36Gm...ature=youtu.be
