Thread: What vacuum line is this??
Results 1 to 7 of 7
  1. #1 What vacuum line is this??
    Donating Users NaturallySmashed's Avatar
    Medford, NY
    I was replacing my thermostat and I broke two vacuum lines... I found someone else that did it and he outlined the picture to show what lines they are... I want to replace these lines, here is the picture http://www.2carpros.com/questions/19...-part-name-for ... thank you.
  2. #2 Re: What vacuum line is this??
    Medford, NY
    Fuel pressure regulator/evap canister purge valve line??? is that what it's called?
  3. #3 Re: What vacuum line is this??
    if its just the line there thats cracked in two, you can put 1 inch piece of vac tubing to join them back together.
  4. #4 Re: What vacuum line is this??
    Medford, NY
    they both cracked off right at the piece where the two lines join together.. right where it meets the intake. i did my best to superglue them back on but idk if that would be permanent lol i rather replace it if I can.
  5. #5 Re: What vacuum line is this??
    i dont know what that large part looks like when the lines are off there, on the right side. if its a round port you can put a fat vac line then a smaller one inside it, then a T on the end, then connect the two lines with vac line to the T.
  6. #6 Re: What vacuum line is this??
    Medford, NY
    when the large part is off it's just one hole that both these lines go into. I could probably get a T and connect it.. the 2 lines aren't classic rubber, they're hard.. idk if that will make it more difficult. i wish i could just find the lines online.. but there doesn't look to be any.
  7. #7 Re: What vacuum line is this??
    the hard lines, you just push them into the vac line. its a permanent repair.
    this is how i fixed my evap line when it broke, the fat line from the side of the TB that turns to the back of engine, with a smaller line pushed inside it, then to the plastic line.
  1. Vacuum Line
    By sumdude in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2011, 03:05 PM
  2. Where is the vacuum line??
    By Bigbm80 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-27-2009, 01:04 AM
  3. vacuum line kit for 98 gtp?
    By Liquifire in forum General Tech Discussion
    Last Post: 11-09-2009, 09:49 AM
  4. Vacuum line
    By drewz313 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 02:11 PM
  5. Vacuum line...where does it go
    By chrizzle17 in forum General Tech Discussion
    Last Post: 02-25-2009, 11:15 PM
