hello, my "service engine soon" light came on so i took my car to autozone and got the codes. the code is p0171 and they said its in there twice.
on the piece of paper they gave me, for the first one all it says is "the pcm has determined that during testing, the fuel system for bank 1 was too lean. (bank 1 identifies the location of cylinder #1 while bank 2 identifies the cylinders on the opposite bank)
for the second one it says
Definition: fuel trim bank one condition
Explanation: the pcm uses the oxygen sensor to calculate the air/fuel ratio of the engine. the computer has recognized a rich or lean condition on one engine bank only
Probable Causes:
1. if bank 1 and 2 codes set together suspect fuel pressure or MAF sensor
2. oxygen sensor defective
3. ignition misfire-repair
4. fuel injector problem
if anyone has any ideas on how to fix this, or any advice, it would be greatly appreciated, thanks
