You may want to power was the coolant out of the motor mount bracket and see if it own up again, it may be residual from the elbows being replaced. It cold also be coming from the water pump or timing cover gasket. Sometimes water pumps don't leak during a pressure test since the pump shift is not spinning. A heater core is no fun to put in.
Sent from my SCH-R970 using Tapatalk
