Thread: Sensors map & maf
Results 1 to 7 of 7
jc71corvette2 Sensors map & maf 12-09-2013, 04:52 PM
02NavyBlue Re: Sensors map & maf 12-09-2013, 07:24 PM
jc71corvette2 Re: Sensors map & maf 12-09-2013, 08:00 PM
jc71corvette2 Re: Sensors map & maf 12-09-2013, 10:54 PM
91parkave Re: Sensors map & maf 12-09-2013, 11:27 PM
jc71corvette2 Re: Sensors map & maf 12-09-2013, 11:34 PM
BillBoost37 Re: Sensors map & maf 12-10-2013, 07:01 AM
  1. #1 Sensors map & maf
    Aug 2013
    ny
    98 gtp. Does it have both sensors ?it has ruff idle even after I unplug the sensor by the throttle body(map?)
  2. #2 Re: Sensors map & maf
    Dec 2012
    Where 4T65E's were born
    It has both.
    If only the idle is rough but other rpms are fine, try cleaning the TB and MAF sensor. If you want to test the maf anyway, you have to unplug it before turning the key on.
    Sold.
  3. #3 Re: Sensors map & maf
    Aug 2013
    ny
    Rpm jumps 2k-4k driving and idlein
  4. #4 Re: Sensors map & maf
    Aug 2013
    ny
    Idles lil bad. And when I drive it'll randomly rev up to 4k and do this few times in a row
  5. #5 Re: Sensors map & maf
    Arizona
    Check your tps
  6. #6 Re: Sensors map & maf
    Aug 2013
    ny
    Wouldn't it be the iac too?
  7. #7 Re: Sensors map & maf
    Not usually.
    Another thing to check is the coil packs.
  1. o2 sensors
    By buschegt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-20-2012, 01:12 PM
  2. O2 and MAF sensors
    By Fox in forum General Tech Discussion
    Last Post: 04-26-2012, 03:02 PM
  3. 02 sensors
    By artsy in forum General Tech Discussion
    Last Post: 06-14-2010, 06:24 PM
  4. O2 sensors
    By Poil336 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-29-2009, 10:30 AM
  5. How many O2 sensors??
    By Tullphan in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-29-2009, 12:32 AM
