Thread: shorter dog bones with poly engine/trans mounts
Results 1 to 9 of 9
  1. #1 shorter dog bones with poly engine/trans mounts
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    is this possible? i got the billet shorter dog bones from zzp and want to do poly mounts as well. anyone done this?
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  2. #2 Re: shorter dog bones with poly engine/trans mounts
  3. #3 Re: shorter dog bones with poly engine/trans mounts
    Mar 2012
    Dallas
    dropping with ssc springs soon, fixing axle geometry, along with the other added advantages
  4. #4 Re: shorter dog bones with poly engine/trans mounts
    the "other added advantages" are things ZZP made up to try and sell pontiac montana dogbones that they got for $2 for whatever they're selling them for.
    they'll not benefit you and you're best off spacing up the motor mounts given that you have some axle bind. you might lose a little hood clearance.
  5. #5 Re: shorter dog bones with poly engine/trans mounts
    Mar 2012
    Dallas
    being that i already bought them, im more looking for answers to my question, rather than alternatives.
    thank you sir
  6. #6 Re: shorter dog bones with poly engine/trans mounts
    i don't see why it's not possible. the mounts will just be a bit stiffer so it might be slightly more difficult to pull the motor forwards to get them bolted in. however, there's no reason why they wouldn't work. watch your fan clearance with the headers, you may have to trim some of the flashing on the fans to get everything to clear nicely.
  7. #7 Re: shorter dog bones with poly engine/trans mounts
    Mar 2012
    Dallas
    okay, thanks.
    i just saw a thread on here, where a member who has a gxp and poly mounts could not move engine forward without "ripping stuff" as they put it
  8. #8 Re: shorter dog bones with poly engine/trans mounts
    Arizona
    Gxp are different we have two lower mounts plus a trans mount. You 3800 guys have one lower mount and one trans mount. Making it easier to pull your engine forward. With poly and the failure rate/cracking of Zzp poly mounts I would highly recomened spacers instead of the pulling the engine forward. You can sell what you have for what you bought it for.and with SSC springs and the mild drop you don't need to do either.
  9. #9 Re: shorter dog bones with poly engine/trans mounts
    Dec 2010
    ATL,Georgia
    they may fit and they may not.. i see you have SD headers so not sure if they will clear the firewall or not. i tried to install the shorter dog bones a while back and my Pacesetters did not clear so i couldn't pull the engine forward enough to install them, as for using them with poly mounts i dont see any issue with that.
    alternative would be like Bio said and just get engine and trans spacers to raise the engine up a little bit.
    04 Top-swapped, 3.2 pulley, ZZP 1.9 rockers w/ #90 springs,Mild P&P heads, Pacesetter Headers, Sseilmnop 2" Phenolic Intercooler with stage 3 HE, ZZP billet fuel rails, 42.5lb injectors, 3" full exhaust, all poly mounts,other supporting mods.
    oh and weight addition mods: CTS-V brake upgrade, 14" GT500 rotors
  1. Custom Poly Trans mounts done Updated 3/7/13
    By 91parkave in forum General Tech Discussion
    Last Post: 01-13-2014, 10:03 PM
  2. 04+ shorter dog bones
    By sca555 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-10-2010, 11:55 AM
