Thread: Crank position sensor?
Results 1 to 12 of 12
  1. #1 Crank position sensor?
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    Hi all,
    So i've been away at school so my car has had some downtime. I have my dad drive it once in awhile however to keep everything running. in August after driving on the highway for about 20 miles the rpms kept jumping around. It seemed like the car was almost stuck in race mode, where it didn't want to shift at its normal points. then after it shifted i would be going about 30 and let off the gas pedal it jumped around and then stalled. got it running after a couple cranks and limped it home. Then it drove perfectly fine for a couple weeks and drove perfectly fine. Then another time i was driving it home it stalled after a left hand turn. 2 days later i was leaving for school and just kind of left it. MY dad has driven it about 8 times and it drove fine except one time. he was driving it up a hill and it stalled. so now fast forward to last weekend, it drove fine but then randomly stalled. then i would start it and it would die or try to stay running at around 400 rpms. so i had to put my foot on the gas for a little to keep it running and to get it to a safe spot. i then started it and shut it off a couple times. after that it drove home just fine. about 6 months ago i got a code about the throttle position sensor, i deleted it to see if it came back but it didn't. So i tested the tps sensor on Saturday thinking thats what was wrong and it was perfectly fine. So i'm thinking its the crank position sensor. I have no codes at all. Am i on the right track or am i completely off? i won't be home for 2 weeks but when i do get home for break i would like to end this problem.
    Thanks,
    Chris
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  2. #2 Re: Crank position sensor?
    Jul 2012
    Chicago
    Sounds like a crank position sensor to me.
    -Carl
  3. #3 Re: Crank position sensor?
    St. Louis
    Do you happen to notice if the tach drops to 0 before it shuts down? This is a tell tale sign of a bad ckps.
  4. #4 Re: Crank position sensor?
    Jun 2012
    Illinois
    yes it bounces up and down, then just goes to zero
  5. #5 Re: Crank position sensor?
    Jun 2012
    Illinois
    when i get home next weekend, im planning on changing it
  6. #6 Re: Crank position sensor?
    Jun 2012
    Illinois
    my cranks sensor is in the mail, however i was just driving it and it stalled but this time threw a p0101 code.... any resemblance? i know its for the MAF but with it stalling does that then throw that code?
  7. #7 Re: Crank position sensor?
    May 2012
    Albuquerque, NM
    On my similar problem I just got the identical code... :-/
  8. #8 Re: Crank position sensor?
    Jun 2012
    Illinois
    i got a new MAF today and put it on. so far so good
  9. #9 Re: Crank position sensor?
    Oct 2011
    Toledo, OH
    Did it turn out to be the snout T ?
    7"
  10. #10 Re: Crank position sensor?
    Jun 2012
    Illinois
    i also noticed that that fell off and i got "new" vacuum lines from the jy and that seemed to help a little too
  11. #11 Re: Crank position sensor?
    SE Level Member Snoop dogg's Avatar
    Dec 2013
    chicago
    i have a similar problem but my GTP doesn't stall my rpm just stay at 1000k on the highway or street i still don't know what it can be.
    ....::::THE DREAMER::::....
  12. #12 Re: Crank position sensor?
    Jun 2012
    Illinois
    no vacuum leaks?
  1. Crank position sensor
    By 94grandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-08-2014, 08:54 PM
  2. New guy from SD, Crank position sensor help.
    By Mak90 in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-15-2012, 09:14 AM
  3. crank position sensor?
    By Mitchstrp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-29-2011, 12:45 PM
  4. HELP Crank Position Sensor
    By catcamvegas in forum General Tech Discussion
    Last Post: 08-02-2008, 10:30 AM
  5. crank position sensor
    By vermsta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2008, 02:41 PM
