This was a whole assembly unit: had the sender, strainer, vapor pressure sensor, everything.
I just popped the pump out to have a look, no clamps at the hoses, appears to be by design. The hoses just appear to be stretched tightly over the connections.
I tried to blow into the "delivery" side of the pump, seeing if I could get air to backflow. It seemed to seal pretty tight, I didn't seem to be getting any air by. A piss-poor test though, maybe it doesn't mean anything. Again, connections all looked good when putting things back together.
Also pulled the vac line of the FPR. No fuel or anything like that. The FPR seems to be performing fine.
Also, no evap codes coming up to imply that there are leaks in my fuel system.
I'm thinking that if Advance Auto will refund me for the pump, I should buy a Delco pump off of RockAuto. I don't really want to "live with" this issue.
