Thread: Coolant Recovery Tank Help
Page 3 of 3 FirstFirst 123
Results 41 to 49 of 49
  1. #1 Re: Coolant Recovery Tank Help
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    flow would be blocked by the thermostat
  2. #2 Re: Coolant Recovery Tank Help
    Mar 2013
    NW Iowa
    Remove the thermostat first?
  3. #3 Re: Coolant Recovery Tank Help
    Dec 2012
    Where 4T65E's were born
    Yes, then feel free to use the garden hose to flush until it's clear, then don't worry about capturing it anymore. You can go the opposite way too, and do the same with the radiator and engine block. The thermostat housing has 2 10mm bolts. Be careful with them, if they're tough to remove, try using it a bit of force in the tightening direction, then go back to loosening. That usually breaks up rust or corrosion and you wont snap bolts off in the engine.
    Sold.
  4. #4 Re: Coolant Recovery Tank Help
    Mar 2013
    NW Iowa
    OK thanks for your help. One last thing I need to ask is about your gutted airbox. Is there a tutorial on how to gut it? I'm all for free mods. Thanks
  5. #5 Re: Coolant Recovery Tank Help
    Dec 2012
    I think there was something linked to me about it before I did it, but I really just took it apart and figured it out for myself and decided how much of what could safely be cut. And yeah I like the free part as well lol. I knew an open cone would really only be an improvement in sound, so I knew I could do the same thing by gutting it and have it be free. It's much more throaty sounding now. And I swear it pulls a little harder now, but I don't see how it would make a noticeable difference. I did get gas shortly after, and put a new PCS in my trans so I bet thats what made the difference. The previous gas was like a month and a half old.
    I'll try to find the post, or the pics of mine.
    My pics: http://www.grandprixforums.net/showt...=1#post1122233
    I finally found it: http://www.grandprixforums.net/showt...=gutted+airbox
    He did a pretty good job, he's got more pictures too. I have plenty to make a write-up too but they're not uploaded. There's a few things you have to know so you don't make a hole or something. In the one pic theres a little square left, thats to keep the PCM in place. In another theres like a half or quarter circle, that's because it's hollow and if you cut it all, you'll have a hole on the top. I considered cutting all of it, and gluing a flat piece of the plastic I cut, but decided it wasn't worth it.
    Sold.
  6. #6 Re: Coolant Recovery Tank Help
    Mar 2013
    NW Iowa
    I'm currently draining the coolant but I wanted to see what you guys think about my method. When done draining the radiator, I'm going to fill with distilled water and let it run for 10-15 minutes to let the thermostat open and let the water through everything. After the car is cooled, I'm going to drain again and after draining I'm going to put my garden hose into radiator cap opening and let it trickle in while it is draining and the car is running to ensure everything is flushed. After this I fill with antifreeze and water. One question I have is how much antifreeze should I use since draining doesn't drain the whole system and there will still be water in the system from the hose? Thanks
  7. #7 Re: Coolant Recovery Tank Help
    Dec 2012
    You really want to remove the thermostat and flush with the hose. The purpose of a flush is to "flush" out contaminants as well as old coolant. It's also good to change the thermostat, especially if it's still original. If the water flow when flushing doesn't exceed the flow during engine operation, you're only removing the liquid in the system. Also, when done flushing the system better be 100% water, and the rest air. At that point, there should still be about 5 quarts of water in the system. Add about 6 quarts of pure antifreeze (NOT 50/50) and the rest can be filled with water. That will give the proper mix since the system capacity is about 12.5 quarts.
    Sold.
  8. #8 Re: Coolant Recovery Tank Help
    Mar 2013
    NW Iowa
    Just add it to the radiator right? When I drained out the coolant, I had a little over a gallon of it. When I put water back in I couldn't fit even a gallon in. Does this sound right? Sorry about all the questions, this is my first time.
  9. #9 Re: Coolant Recovery Tank Help
    Dec 2012
    Yes. And yes that's normal, the rest was air. It will eventually be bled and will need more
    Sold.
  1. 97/98 coolant tank
    By gtpsleeper in forum Wanted To Buy - Parts
    Last Post: 05-26-2013, 12:29 AM
  2. 97 coolant overflow tank
    By RedGrandprixgt53 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-30-2012, 04:09 PM
  3. Coolant recovery tank leak?
    By jagamite in forum General Tech Discussion
    Last Post: 12-01-2009, 03:40 AM
  4. coolant recovery?
    By 98GPGT in forum General Tech Discussion
    Last Post: 12-17-2008, 11:00 AM
