Thread: Need Help Fast!! Found this in drain pan!!!
Results 1 to 6 of 6
  1. #1 Need Help Fast!! Found this in drain pan!!!
    Oct 2011
    WI
    Figured I'd post this here too. Did a transmission fluid change last night. Set the drain pan on my jug to drip dry and found this clip in the pan this morning. It has to be from the transmission, but I'm not sure from where. My guess is I'll be ripping that pan off again but I'd love to know where the clip goes. Any help would be appreciated. Thanks!!
    Need Help Fast!!  Found this in drain pan!!! Attached Images
  2. #2 Re: Need Help Fast!! Found this in drain pan!!!
    That is a thermo switch of a sort. It helps block a passage. Picture coming up.
    Here ya go
  3. #3 Re: Need Help Fast!! Found this in drain pan!!!
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    Make sure the 2nd piece is found also. It's a 2 piece design. Other than that it's a very simple fix.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  4. #4 Re: Need Help Fast!! Found this in drain pan!!!
    What he means is there's a flat piece under it. In my experience you only bumped or found the bent piece and the flat is still where it belongs.
  5. #5 Re: Need Help Fast!! Found this in drain pan!!!
    Little late to the party old man, helped him in the double thread.
  6. #6 Re: Need Help Fast!! Found this in drain pan!!!
    Good job Cammer..
    And Greg showed up even later!
  1. Need Help Fast!! Found this in drain pan!!!
    By rg567 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-23-2020, 12:23 AM
  2. Need Help Fast!! Found this in drain pan!!!
    By rg567 in forum General Grand Prix Discussion
    Last Post: 11-03-2013, 01:14 PM
  3. One Screaming Fast Turboed GTP Found On YouTube
    By JimSWylie in forum General Grand Prix Discussion
    Last Post: 09-17-2013, 08:09 AM
  4. That is a fast Grand Prix, I don't think they were meant to go that fast
    By Explicit_Spade in forum Off Topic Discussion
    Last Post: 07-04-2011, 11:32 AM
  5. radiator drain o-ring size? FAILED motormite drain.
    By alacran in forum General Tech Discussion
    Last Post: 04-03-2010, 08:16 PM
