Thread: Help find out whats going on with my 1st front left cylinder
Results 1 to 20 of 52
  1. #1 Re: Help find out whats going on with my 1st front left cylinder
    I wouldn't push that after seeing those compression numbers.
    I think you should visit crappy before they close and get a proper spark plug.
    NGK TR55 because they're cheap.
    Do you see blue smoke on startup?
    I know it's been kinda cold lately, so a lot of condensation will be expected.
    How old are the wires?
    Check for continuity from the O2 sensor connecter to the PCM. If they check out, you likely need a new sensor. Alternatively the PCM is dead or dying.
  2. #2 Re: Help find out whats going on with my 1st front left cylinder
    Oct 2013
    Toronto
    you would'nt push what scrapping the motor cause i dont think its going to need that i put proper tr55 in there and same outcome on just that 1 cyl
    white smoke out the back but that just the oil in the chamber for the test no blue smoke only white coming out. if the pcm was dead i think id get more codes then just the 02 one but thanks for helping matt.
    this cars got a mint body on it so i wanna keep this powerplant if possible so iam going to take it to a shop tomorrow and get then to yank of the front heads and have a look at that 1cyl from top and bottom just everything iam thinking point towards the head. and that was not touched when the cyl was replaced the first time time so maybe the mechanic never got a good look at the head before he put it back on.
  1. Whats your Cylinder Index?
    By GtpKo in forum Off Topic Discussion
    Last Post: 05-03-2011, 10:11 AM
  2. Shaking in front left tire
    By InfidelRebel in forum General Tech Discussion
    Last Post: 09-27-2009, 07:58 AM
  3. noise in front end, left side
    By Jimbo in forum Introductions/Noob Questions
    Last Post: 08-14-2009, 04:21 PM
  4. Left Front Speakers don't work...
    By Gannon2145 in forum Audio, Security & Visual Electronics
    Last Post: 03-17-2009, 07:56 PM
