Thread: Help find out whats going on with my 1st front left cylinder
Results 1 to 20 of 52
Threaded View
  1. #11 Re: Help find out whats going on with my 1st front left cylinder
    Oct 2013
    Toronto
    Standard will have a bunch of L26s in stock for a good price.
    and Ya standard had the gt versions in scarborough but the only sc motor they had was in new york for $500 but has 312000km on it mines only got 225k so i might be just as bad swapping that one straight in there.
    where you located matt? iam in the whitby area
    what do you mean l26 is that the lower block number? do they use the same pistons? i thought the SC version would be higher compression pistons?
    i thought i had the l67/l32 motor.
    So scotty would you think a chipped piston would let oil right into the sparkplugs/ combustion chamber and if so would i need to machine the bore or sleeve it or would it just be a swap of the piston piston rings and rods? i know its just theroy until i get a compression test and pull codes but at least i could sleep better knowing that tonight lol
    That could be causing the detonation. i hope so cause i hate to pull the motor if that was only the case.
  1. Whats your Cylinder Index?
    By GtpKo in forum Off Topic Discussion
    Last Post: 05-03-2011, 10:11 AM
  2. Shaking in front left tire
    By InfidelRebel in forum General Tech Discussion
    Last Post: 09-27-2009, 07:58 AM
  3. noise in front end, left side
    By Jimbo in forum Introductions/Noob Questions
    Last Post: 08-14-2009, 04:21 PM
  4. Left Front Speakers don't work...
    By Gannon2145 in forum Audio, Security & Visual Electronics
    Last Post: 03-17-2009, 07:56 PM
