its weird that the system is activating at all. when fault's are detected the system should disable itself.
Originally Posted by slimguns It's the "Service Traction System" and then the "Trac Off" light also comes on and stays on. Wheel slip is very limited if any, VERY minor as I don't generally take off hard. I'm having the same problem with the stock '04 GTP... What could it be?
Forum Rules
