Thread: radiator fans do not come on at over heat temperature
Results 1 to 20 of 21
  1. #1 Re: radiator fans do not come on at over heat temperature
    Dec 2012
    Where 4T65E's were born
    Why did you order new fans if you said yours came on when jumped? Check all fuses first. If you confirmed that the relay was working, make sure that the wires leading to the power distribution box are hooked up and getting voltage. If so, check for power at the connector to the fans. If you get power there, but not to the fans, the contacts could be dirty. If you don't get power to the fans but did at the relay, check the wires and the ground. That may be the issue.
    You didn't mention what car you're driving, but assuming its a grand prix, and a 97-03 here's a wiring diagram.
    Check ground 117 and power to both fans, just keep tracking power til you lose it, then find out why.(assuming the relays do click but no fans)
    Sold.
  2. #2 Re: radiator fans do not come on at over heat temperature
    Sep 2013
    point pleasant nj
    i will check grounds tomorrow,also pop the tops of all 3 relays to see if heavy contacts will activate when pushed in by hand..
  1. Radiator fans not working
    By Paul Hagensick in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-18-2012, 08:25 PM
  2. Radiator Fans
    By Garry in forum General Grand Prix Discussion
    Last Post: 05-18-2012, 09:08 AM
  3. radiator fans not working
    By Wisconsingrandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2012, 07:59 PM
  4. Should my radiator fans be on all the time?
    By yekimmrt in forum General Tech Discussion
    Last Post: 12-20-2010, 07:26 AM
