Thread: fbody rear calipers help
Results 1 to 20 of 21
  1. #1 fbody rear calipers help
    Feb 2015
    california
    Just installed front fbody calipers on my 02 gtp. Got to rear fbody calipers and no threading on the caliper bracket. Am I supposed to tap the holes? If so for what bolt size. I got the red powder coated powerstop fbody calipers.
  2. #2 Re: fbody rear calipers help
    you dont use the rear brakes. they dont fit.
  3. #3 Re: fbody rear calipers help
    Feb 2015
    california
    Quote Originally Posted by ScottyDoggs View Post
    So even if holes were tapped they dont fit? What do you mean?
  4. #4 Re: fbody rear calipers help
    no one uses them. not sure what the end issue is, wheel clearance or there're not worth using. not sure.
  5. #5 Re: fbody rear calipers help
    Feb 2015
    california
    Well I have 18 inch rims I think I'm good on clearance. I dont mind if its even a small upgrade I've already bought them. Just seems the holes on brackets need to be tapped for the install to be made like fronts were
  6. #6 Re: fbody rear calipers help
    wait till tomorrow when more eyes hit this post. they just not be worth it is a lot of what i hear, still a single piston caliper.
  7. #7 Re: fbody rear calipers help
    hangover park IL
    iirc it'll be an integral parking brake caliper much like the 04/05 compG used to get rid of the additional weight of the parking brake "drum in the hat" stuff
    ~James~ Psychotic Gearhead
  8. #8 Re: fbody rear calipers help
    Feb 2015
    california
    Quote Originally Posted by Turbocharged400sbc View Post
    So get the compg rear calipers instead?
  9. #9 Re: fbody rear calipers help
    Donating Users timboku's Avatar
    Montgomery, IL
    Gxp rears bolt right up to 02..that's what I have on mine, comp gs will not, the parking brake is different, plus the god are better, 12 inch rotor
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  10. #10 Re: fbody rear calipers help
    Feb 2015
    california
    Quote Originally Posted by timboku View Post
    Will the fbody rear rotor work with rear grand prix gxp calipers? I bought them already. Also would changing the rear rotor to aftermarket get rid of the e brake?? I guess what i want to know is whats the best upgrade here for the rear brakes? Im guessing youll just say nice new pads..
  11. #11 Re: fbody rear calipers help
    Nov 2013
    Wisconsin!
    The only upgrade is gxp rears. I think someone did a ctsv rear too, but the fab work makes it pointless unless you do it yourself.
    And no, changing rotors does not get rid of your abs.
  12. #12 Re: fbody rear calipers help
    Montgomery, IL
    Fbody rear rotors won't work..they are different
  13. #13 Re: fbody rear calipers help
    Enfield, CT
    Yea F- Body rear calipers isn't going to work without big modifications. Stick with the stock rear calipers or upgrade to the 04+ GP calipers.
    Sent from my LG G3
  14. #14 Re: fbody rear calipers help
    SE Level Member brokeazfunk's Avatar
    Aug 2013
    Phoenix Az
    Good to know! getting ready to do front F body upgrade soon and was wondering about the rears. Glad I read this.
  15. #15 Re: fbody rear calipers help
    keep in mind your changing the rear knuckle also to swap brakes from a 04 up, and you need the e brake cables to work with them.
  16. #16 Re: fbody rear calipers help
    Enfield, CT
    E-brake cables yes. I was told the knuckles were the same. Lemme check
    Sent from my LG G3
  17. #17 Re: fbody rear calipers help
    Enfield, CT
    No info on gm parts direct. Junk yards show 2003-2012 but that's most likely due to the Imapala. For safe measure, just grab rear knuckles from 04+.
    Sent from my LG G3
  18. #18 Re: fbody rear calipers help
    Montgomery, IL
    The gxp rears bolt directly to a 97 to 03 rear knuckles..it's the same as the gxps, the rear ebrake is in the rotor hat for the gxp, the 04 plus non gxp ebrake is built into the caliper....for gxp rear up grade in a 97 to 03 all you need is calipers, brackets, rubber brake lines, and rotors off a 05 to 08 gxp..bolts right up...nothing else is needed
  19. #19 Re: fbody rear calipers help
    Feb 2015
    california
    thank you for this info. Now to find powder coated powerstop gxp rear calipers.. Anyone know where to find them? Also is there any real benefit to the gxp front calipers over fbody?
  20. #20 Re: fbody rear calipers help
    Montgomery, IL
    Gxp fronts are a little bigger rotor than fbody.
  1. GXP rear calipers
    By Logan541 in forum Wanted To Buy - Parts
    Last Post: 09-08-2014, 02:35 PM
  2. rear calipers
    By Wadeb79 in forum Brakes/Suspension/Chassis
    Last Post: 08-22-2012, 03:56 PM
  3. Fbody calipers.
    By LeadFoot in forum Brakes/Suspension/Chassis
    Last Post: 04-13-2012, 08:39 PM
