Quote Originally Posted by timboku View Post
The gxp rears bolt directly to a 97 to 03 rear knuckles..it's the same as the gxps, the rear ebrake is in the rotor hat for the gxp, the 04 plus non gxp ebrake is built into the caliper....for gxp rear up grade in a 97 to 03 all you need is calipers, brackets, rubber brake lines, and rotors off a 05 to 08 gxp..bolts right up...nothing else is needed
thank you for this info. Now to find powder coated powerstop gxp rear calipers.. Anyone know where to find them? Also is there any real benefit to the gxp front calipers over fbody?
