View Poll Results: Which Option would you take?
Voters
6. You may not vote on this poll
  • Option 1
    2 33.33%
  • Option 2
    4 66.67%
  • Option 3
    0 0%
  • Option 4
    0 0%
Thread: Need engine work. What would you do?
Results 1 to 8 of 8
orange57 Need engine work. What would... 10-19-2013, 04:27 PM
dsmuts Re: Need engine work. What... 10-19-2013, 04:28 PM
REDCRAPGP Re: Need engine work. What... 10-20-2013, 05:23 AM
tms8582 Re: Need engine work. What... 10-20-2013, 08:01 AM
orange57 Re: Need engine work. What... 10-20-2013, 11:57 AM
97gtpjoe Re: Need engine work. What... 10-20-2013, 12:05 PM
orange57 Re: Need engine work. What... 10-20-2013, 03:22 PM
16MustangVet Re: Need engine work. What... 10-20-2013, 12:51 PM
  1. #1 Need engine work. What would you do?
    GT Level Member orange57's Avatar
    Aug 2012
    Chandler, AZ
    Do I need engine work. Short story, front main seal blew out, now have a slight knock from the engine. Car is a 2004 Grand Prix GTP. I'm looking at a couple of options
    Option 1:
    Pick up a low mileage L26 NA engine and top swap over. I can get one locally with the range of 10-50K miles for around $450-650.
    Option 2:
    Pick up a higher mileage L36 NA engine and top swap over. I have seen several with mileage ranging from 80K-150K for the same $450-650 locally.
    Option 3:
    Pick up a brand new crank, bearings, rings and oil pump and do a pseudo rebuild. I'm sure there will be more I'd need to replace as well.
    Option 4:
    Sell the car for scrap and find one thats running.
    I left out trying to pick up a S/C engine, as generally, locally they go fro $1200 plus, with greater than 100K on them. I have seen a cuople of GP's and other vehicles with the 3800 in them for about the same price as a used S/C engine.
    What option would you pick?
    matt
    2004 Grand Prix GTP - work in progress
  2. #2 Re: Need engine work. What would you do?
    Don't rebuild it. Do the cheapest top swap
  3. #3 Re: Need engine work. What would you do?
    This!
    No sense in scrapping it as long as it's still in ok condition. 3800s are plenty available.
    04 Comp G.
  4. #4 Re: Need engine work. What would you do?
    GTP Level Member tms8582's Avatar
    Washington Michigan
    It all depends on the condition of your car. If its a really nice car id swap the short block. Another factor is your ability or extra cost involved to swap the motor... Do you have to pay a mechanic or can you get it done yourself? If its a pos its not worth the work in my opinion.
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  5. #5 Re: Need engine work. What would you do?
    Aug 2012
    Chandler, AZ
    body is in great shape. Interior, a little rough, but looks good when cleaned up.
    I can do all the work myself. Wouldn't be the first motor swap I've done. Just need to pick up a hoist and engine stand. It's basically been a time thing. Haven't had much free time.
    matt
  6. #6 Re: Need engine work. What would you do?
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    Quote Originally Posted by orange57 View Post
    Is your car posted on craigslist? http://phoenix.craigslist.org/evl/cto/4140669743.html . Been noticing this ad for a while now
    I would fix it
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  7. #7 Re: Need engine work. What would you do?
    Aug 2012
    Chandler, AZ
    Quote Originally Posted by 97gtpjoe View Post
    I would fix it
    Yep, sure is. I took it down for a while, as I had someone that was going to take it, and swap in the engine from their totaled buick regal. But that fell through. And then my travel for work has been picking up, so I haven't had much time to do anything. I just relisted it the other day.
    I think it could be a really fun car, and I really like the 3800 platform. It's jsut not having time to play with it. Work and the newborn suck up a lot of time Well, pretty much all of it ha ha
    If I can clear enough space in the garage, then it won't be too bad to store it. But i'm sure my HOA is going to be harassing me again soon.
    matt
  8. #8 Re: Need engine work. What would you do?
    Id use the L26 engine lowest mileage with the best price, sure the L36 had a better bottom end but unless you plan on doing a bunch of mods the L26 will be fine and the added compression would be nice too. Just my opinion.
  1. no start after engine work!
    By bwc1987 in forum General Grand Prix Discussion
    Last Post: 08-18-2013, 09:58 AM
  2. Did some engine bay paint work
    By Biohazed in forum Visual/Body Modifications
    Last Post: 05-20-2010, 10:56 PM
  3. Finally did some engine work.
    By silvermistgt2002 in forum Visual/Body Modifications
    Last Post: 05-02-2010, 11:57 AM
  4. Engine Work
    By MakeitLouder97 in forum Introductions/Noob Questions
    Last Post: 03-24-2010, 03:53 PM
