Thread: Magnasteer reset!
Results 1 to 6 of 6
  1. #1 Magnasteer reset!
    Feb 2013
    Duluth, mn
    so i was playing around the other day and was cornering on some side roads and my stability control was activated around a turn. i pulled into my driveway and i had no power steering. it does however work when it gets to about 3k rpm. but it makes for a very difficult time parking ect. i tried to disconnect the battery for around a hour.. i then tried to pull the abs fuse.. (that just set the sensors off for everything) i then tried to unplug the wire leading to the rack and all that did was just set the service light for the steering... im at a loss.. i dont think the rack is bad or the pump....how the heck do i reset the magnasteer??
  2. #2 Re: Magnasteer reset!
    Your rack is shot it's not the magnasteer.
  3. #3 Re: Magnasteer reset!
    Feb 2013
    Duluth, mn
    im not sure its the rack. it doesn't leak or wonder or have alot of play. and its stiff both ways not just right or left. there's no noise. i dont know but usually when ive had a rack go they usually have more symptoms than a faulty low rpm assist..
  4. #4 Re: Magnasteer reset!
    When mine went bad it had no symptoms before hand just all the sudden couldn't turn left.
  5. #5 Re: Magnasteer reset!
    Feb 2013
    Duluth, mn
    yeah they usually only give out one side at a time thats why im thinking its not the rack cuz i cant turn right or left.
  6. #6 Re: Magnasteer reset!
    GTP Level Member Twizted 1's Avatar
    Jul 2013
    Summertown Tn
    The pressure regulator in my wife's powersteering pump stuck and caused that same problem. You could keep the rpms up and it would steer fine.
    After installing 3 pumps from advance I finally got a good one.
  1. What is magnasteer ? Magnetic assistance ?
    By JT2002GTP in forum General Grand Prix Discussion
    Last Post: 12-13-2016, 03:32 PM
  2. Magnasteer wire
    By MontyJ in forum Brakes/Suspension/Chassis
    Last Post: 08-23-2012, 05:44 PM
  3. Need help determinning if I have magnasteer.
    By bigtom9492 in forum General Tech Discussion
    Last Post: 12-13-2011, 05:11 PM
  4. Is magnasteer and reg rack interchangable?
    By dsmuts in forum Brakes/Suspension/Chassis
    Last Post: 04-13-2011, 04:55 PM
  5. ABS and/or Magnasteer problems
    By cogsracing in forum Brakes/Suspension/Chassis
    Last Post: 02-02-2011, 08:33 PM
