Thread: Driving with worn steering?
Results 1 to 3 of 3
nickgpgt Driving with worn steering? 10-15-2013, 01:10 PM
FordMan77 Re: Driving with worn... 10-15-2013, 02:08 PM
nickgpgt Re: Driving with worn... 10-15-2013, 02:19 PM
  1. #1 Driving with worn steering?
    Apr 2013
    Michigan
    So my steering system is somewhat worn I assume, my last mechanic when I first got the car told me my rack and pinion is wearing out and that was like 9 months ago. I can still steer fine the steering wheel just doesnt come back as fast as a newer car would, it is leaking power steering fluid and i never got around to fixing it i just fill the reservoir like once a month. am i at any danger driving it like this? i will get the leak actually checked eventually just cant right now
  2. #2 Re: Driving with worn steering?
    St. Louis
    As long as it's full on fluid you should be fine. I drove mine for way longer on a bad rack. The only downside was that once it went, I could barely turn left at all (like pull with both arms as hard as I could to make the turn and not wreck it).
    Easy to check for the leak yourself. Grab some degreaser and spray all the lines and rack down, and hose it off. Fire it up and let the leak occur again and take a peek under the car and spot the leak. Probably either a seal on the inner tie-rod, or one of the lines at the pump leaking. Could be the pump itself too.
  3. #3 Re: Driving with worn steering?
    Apr 2013
    Michigan
    alright thanks, i might be selling the thing anyways because of the strut tower rust, i dont really want to but starting to look like i dont really have a choice
  1. steering seizing and car stalling while driving 06 GP se
    By stumpee1 in forum General Grand Prix Discussion
    Last Post: 01-24-2013, 11:42 PM
  2. Driving with a bad power steering pump
    By Chad Gervais in forum General Grand Prix Discussion
    Last Post: 08-25-2012, 01:16 AM
  3. Worn lower control arm bushings?
    By justind in forum Brakes/Suspension/Chassis
    Last Post: 11-27-2011, 01:17 PM
  4. steering seems like driving a boat? HELP!
    By putskijr in forum Brakes/Suspension/Chassis
    Last Post: 02-13-2010, 02:20 AM
  5. which worn parts to replace at almost 90k miles?
    By AmericanSoldier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2010, 11:30 AM
