Thread: Brake light and turn signal issue
Results 1 to 10 of 10
  1. #1 Brake light and turn signal issue
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    98 grand prix. Both front turn signals work..rear driver side brake and turn signal work..passanger side brake and turns signal do not work as long as the middle brake light. Chased the wiring and checked all that out checked the fuses all good. Any ideas what could make the middle brake light and the passanger side brake light and turn signal not work?
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  2. #2 Re: Brake light and turn signal issue
    Kinda a dumb question, but did you swap the bulbs yet?
  3. #3 Re: Brake light and turn signal issue
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    ^^^ Lol
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  4. #4 Re: Brake light and turn signal issue
    Jul 2011
    Michigan
    Yes the bulbs have been swapped
  5. #5 Re: Brake light and turn signal issue
    the bulb socket could be dead from moisture over the years. take it out clean it up.
  6. #6 Re: Brake light and turn signal issue
    Jul 2011
    Michigan
    Probably should have noted that i have no power going to the bulb socket at all. Dad and i tested it and there was nothing...
  7. #7 Re: Brake light and turn signal issue
    prob the wires before the plug to the socket for power, if its still dead, start tracing the wires and look for damage, that loom of wires that runs under the trunk hinge is always guilty and worth a look at.
  8. #8 Re: Brake light and turn signal issue
    Jul 2011
    Michigan
    now there is no brake or turn signal on both sides of the rear...
  9. #9 Re: Brake light and turn signal issue
    Jul 2011
    Michigan
    I have no idea what is going on now. It started off with the right brake light and rear blinker not working....Now both sides stopped working. I replaced the turn signal switch, all the relays under the dash, the brake switch, and all the fuses, bulbs, and no visible wire damage anywhere. Im at a complete loss here
  10. #10 Re: Brake light and turn signal issue
    May 2011
    jacksoncille nc
    Having the same issue as you are. Did you get this resolved? Fuses good, changed the flasher relay(now front don't flash fast anymore), changed all bulbs, cleaned the bulb terminals, took off signal assembly and cleaned all contact terminals...looks good though, still no signal to the bulb.
  1. 08 turn-signal & brake light issue
    By Dee Johnson in forum General Grand Prix Discussion
    Last Post: 10-03-2012, 02:22 PM
  2. turn signal issue please help if you can.
    By sUpErClEaNbLaCkMaChInE in forum General Tech Discussion
    Last Post: 12-08-2011, 09:36 PM
  3. 05 GTP Turn signal issue
    By ubmarine in forum Audio, Security & Visual Electronics
    Last Post: 05-03-2011, 07:45 PM
  4. 2005 GT Turn signal issue.
    By Mac2005GT in forum General Tech Discussion
    Last Post: 04-07-2011, 10:29 PM
  5. Brake light, turn signal, cigarette lighter wont work
    By dlouis30 in forum Introductions/Noob Questions
    Last Post: 03-02-2010, 10:07 PM
