Thread: Vent Selector Knob does nothing
Results 1 to 5 of 5
slikrider20 Vent Selector Knob does... 11-11-2013, 11:19 PM
Fivefingerdeathpunch Re: Vent Selector Knob does... 11-11-2013, 11:20 PM
tech3627 Re: Vent Selector Knob does... 11-12-2013, 07:13 AM
Turbocharged400sbc Re: Vent Selector Knob does... 11-12-2013, 08:40 AM
slikrider20 Re: Vent Selector Knob does... 11-12-2013, 10:17 PM
  1. #1 Vent Selector Knob does nothing
    Apr 2013
    United States
    Hello all, i have a 2000 Pontiac Grand Prix GT. 195,000 miles.
    Have a problem with the vent selector knob. No matter where i set the knob, it seems to distribute the air throughout all the vents evenly. Nothing changes when i turn the knob. The blower works fine on 1-5, and the temperature control also works fine. My cruise control works. What do you guys think the problem is? I've had a hard time finding much information on this on the internet. Thanks in advance
  2. #2 Re: Vent Selector Knob does nothing
    Sounds like a blend door issue.
  3. #3 Re: Vent Selector Knob does nothing
    Jun 2011
    Texas
    It is very common to have the knob itself brake. Pull the knob off and look to see if it is cracked around the center. Sometimes the metal sleeve stays on the shaft also.
  4. #4 Re: Vent Selector Knob does nothing
    hangover park IL
    vent select knob probably means its a non auto climate control head so im gonna say its a vacuum actuator
    check the vac supply line/resevoir bulb for vac, the line should go across from the pass strut tower to the 3 way vac tee on top of the blower
    ive seen the knob break but thats usually after the initial problem as they "beat the **** out of it" trying to get it to work
    ~James~ Psychotic Gearhead
  5. #5 Re: Vent Selector Knob does nothing
    Apr 2013
    United States
    I will check the things listed so far, thanks for the ideas. And by the way, it is a non auto climate control.
  1. Gear selector lever popping off on 4t65
    By buickman104 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-24-2012, 06:49 AM
  2. Problems with gear selector switch
    By Jordanmccarty in forum General Tech Discussion
    Last Post: 03-02-2012, 07:24 PM
  3. Gear selector lights
    By Freimuth in forum General Tech Discussion
    Last Post: 09-15-2011, 09:13 AM
  4. Brake switch for shift selector
    By threegtoman in forum General Tech Discussion
    Last Post: 12-27-2010, 12:51 PM
  5. shift selector lever very stiff
    By almighty in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-19-2009, 05:18 PM
