Thread: Coolant smell
Results 1 to 3 of 3
  1. #1 Coolant smell
    Akron, Ohio
    Well, here goes. I am going to start from the beginning and for some of you who helped me on other threde there may be a lot of repitition, but I think it is therapy to tell the story. And for what it is worth, the car has never overheated.
    2006 Grand Prix GT. I drove it for years. The coupe years I smelled coolant but never had to add any. I did have issues with no heat at times and a gurggling with acceleration. I treated this with flushing the heater core. It would work for a few months, then I had to do it again. I did this for the last 2 years without a problem.
    Then the smell got stronger last spring. Took to a shop and they showed me a slow leak in the radiator. I replaced this and the thermostat and radiator and went back to smell without coolant loss. Still had coolant smell and gurggling on acceleration.
    Then 2 months ago noticed coolant smell in the car and coolant loss. Inspection showed a little coolant below the water pump. So I replaced the heater core and the water pump. This did not fix the problem of coolant loss or the sound. I had heat though.
    So I bought a dye test, pressure tester, and block tester. Tested the block. No exhaust gas in the coolant. Put the dye in and no dye in oil. Saw a leak on the side of the LIM. Thinking coolant could leak there, with the help of this site, I replaced the LIM and the elbows. Found the problem finally, one of the elbows had a crack in it.
    Got the car back together and have been driving for 2 weeks. Car runs perfect, no gurggling, good heat, no hesitation (problem I was not worried about, but it is gone now - I think from replacing the vacuum lines)
    But...Still have a coolant smell after a drive. I can not smell it inside the car, but as soon as I get out I smell it. For the first two trips after I did all the work I had to add a small amount of coolant, but none in the last week. Pressure test drops maybe 1mmHg in 30 minutes.
    So am I crazy? Scratch that, I know the answer to that.
    Should I be concerned? I see no coolant anywhere in the engine compartment. The smell is from the side of the water pump. Hot or cold - no coolant on engine. Just that dang smell.
  2. #2 Re: Coolant smell
    long shot but maybe de grease the engine, outs side fins of the rad, full engine bay really, rinse it all down good. see if the smell comes back.
    hows your rad cap btw? is it new? and how the over flow tank, 1/2 full or full to the top and over flowing maybe?
  3. #3 Re: Coolant smell
    Buffalo NY
    Ive noticed that the smell usually is a result in coolant that made still reside on the engine some where cooking away.. it usualy smells like that for a month until it burns away.. I smelled the same thing in my 07 after doing a heavy duty flush and burping of air in the system.. Its almost impossible to do a coolant change properly without getting some coolant somewhere on the engine lol
  1. Oil leak and coolant smell
    By littlerobinson75 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-01-2012, 05:33 AM
  2. faint coolant smell..
    By danielle15 in forum General Tech Discussion
    Last Post: 04-04-2011, 08:33 PM
  3. I smell coolant but can't find a leak 01 GP GTP
    By smooth01gtp in forum Introductions/Noob Questions
    Last Post: 02-16-2010, 07:06 AM
  4. Coolant smell in car
    By thewaitinggame in forum General Tech Discussion
    Last Post: 12-13-2009, 04:21 PM
  5. coolant smell
    By Charged97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-17-2009, 12:46 PM
