Thread: ZZP vs Thrasher Shift kit
Results 1 to 20 of 20
  1. #1 ZZP vs Thrasher Shift kit
    Nov 2008
    Chicago
    My trans is on its way out and I'm putting a trans cooler and a shift kit on the new one. The cooler will be flared and double clamped to prevent failrure.
    What's your opinion on these two shift kits as far as quality goes? I'm looking for the most reliable solution.
    Also, is there anything that should be kept in mind if i plan on upgrading the PCM since it'll increase the line pressure?
    Thanks!
  2. #2 Re: ZZP vs Thrasher Shift kit
    Jersey
    zzp one is a waste of money. Go with the Intense shift kit, its the most complete shift kit you can get. Im not sure about the PCM tunning.
    16' wrx sti- stock
  3. #3 Re: ZZP vs Thrasher Shift kit
    Nov 2008
    Chicago
    Does anyone know the real advantage to the additional parts in the more expensive kits?
  4. #4 Re: ZZP vs Thrasher Shift kit
    Jul 2008
    sumter,south carolina
    just get a trans from triple edge performance
    02 GTP with mods 05 GP for DD
  5. #5 Re: ZZP vs Thrasher Shift kit
    Nov 2008
    Chicago
    my warranty doesn't cover performance parts I'm hoping that i can at least get them to pay for a rebuilt jasper trans
  6. #6 Re: ZZP vs Thrasher Shift kit
    I live here. UR LOSN's Avatar
    Rockford, IL
    Trans Go shift kits FTW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!
  7. #7 Re: ZZP vs Thrasher Shift kit
    Nov 2008
    Chicago
    Hah! Fred Flinstone brand trans FTW!
    Haha... Seriously, does anyone know what these extra parts do? My trans is on the way out and im hoping I can beat the piss out of it until i hear a loud pop right outside of the shop
  8. #8 Re: ZZP vs Thrasher Shift kit
    Barksdale AFB, LA
    Quote Originally Posted by FuglyGTP View Post
    ZZP's kit is just a couple nylon spacers. The Intense kit comes with all new springs to tailor it to how you want, new accumulator gasket, new filter, everything you need to prepare the accumulator bores properly, etc.
    It's a complete kit, instead of the bare essentials (if you could call nylon spacers that). Adding spacers only isn't the proper way to do it anyway.
    2009 Subaru Impreza WRX STI
  9. #9 Re: ZZP vs Thrasher Shift kit
    Jul 2008
    Germantown, Maryland
    x2^
  10. #10 Re: ZZP vs Thrasher Shift kit
    Nov 2008
    Chicago
    I'm having the trans shop put it in when they put in a new trans BTW
  11. #11 Re: ZZP vs Thrasher Shift kit
    Banned
    Wichita Falls, Texas
    ZZP is a POS.
  12. #12 Re: ZZP vs Thrasher Shift kit
    Nov 2008
    Chicago
    Can you please explain why?
  13. #13 Re: ZZP vs Thrasher Shift kit
    Banned
    Because it's plastic?
  14. #14 Re: ZZP vs Thrasher Shift kit
    Jul 2008
    yea, this argument has been going on for awhile now, and Intense always wins..
  15. #15 Re: ZZP vs Thrasher Shift kit
    Nov 2008
    Chicago
    How about Thrasher vs INTENSE?
  16. #16 Re: ZZP vs Thrasher Shift kit
    Banned
    Either will work well.
  17. #17 Re: ZZP vs Thrasher Shift kit
    Nov 2008
    London
    Thanks!
    I went with the Thrasher on my '99GTP. I had a turbo set up at the end and pulled low 12's all day long on low boost. I was very happy with the thrasher as it was more 'user tuneable'. I had a zzp pcm with increased line pressure and and cooler... never gave me a problem. Heard bad things with the zzp kits and that was direct from zzp themselves when they first marketed the product. I don't think they revised as it worked 'well enough'... go Thrasher and you'll be happy from mild to wild.
  18. #18 Re: ZZP vs Thrasher Shift kit
    Jul 2008
    thrasher is what I was thinking of.... not intense
  19. #19 Re: ZZP vs Thrasher Shift kit
    Toronto
    The Thrasher and Intense kit are both over priced. You get the exact same thing if you buy a $45 Trans Go shift kit and add the spacers yourself.
  20. #20 Re: ZZP vs Thrasher Shift kit
    Nov 2008
    Chicago
    That's actually a really good idea Drew! However I think I'll spend an extra $30 make sure that I use the right size spacers and whatnot. I greatly appreciate all of your input and have decided to go with the Thrasher kit. Thank You!
  1. Thrasher ?
    By Meemperor in forum Off Topic Discussion
    Last Post: 04-17-2008, 10:05 AM
  2. Thrasher vs Transgo shift kit
    By anks106 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-03-2008, 10:21 PM
