Thread: How NOT to melt your fog lights
Results 1 to 16 of 16
  1. #1 How NOT to melt your fog lights
    Nov 2008
    Chicago
    Hey all! I just got a pair of smoke headlights and I know how much it cuts down on the light output. On my 300zx i upgraded the fog lights from 55w to 100w without any problems. From what I've been reading, I hear that an upgrade to 55w doesnt create any issues. Has anyone tried the 100w bulbs? Rewiring isn't an issue, I'm just worried about melting the housing and/or the front bumper. Thanks in advance!
  2. #2 Re: How NOT to melt your fog lights
    I live here. UR LOSN's Avatar
    Rockford, IL
    I havent heard of anyone doing this..... as everyone just upgrades to the HID kits. they use less power, and are by FAR brighter!
    the stock housings are made of plastic. I had a buddy use zeon bulbs off ebay..melted his fog light......
  3. #3 Re: How NOT to melt your fog lights
    Quote Originally Posted by UR LOSN View Post
    there is no way on this planet that your HID bulbs can match the light output from a 130W H3 bulb in some glass housings. i ran some for a week or so but kept popping the fuse. they were brighter than all hell.
    i havent gotten around to redoing them yet, but we'll see if i ever do cause im lazy and my HID headlights do just fine.
  4. #4 Re: How NOT to melt your fog lights
    Banned
    May 2008
    VA (was NY, MI, MN, FL)
    I run 100w H3's in clear Hella Optilux 1300 glass housings that were about $35 (basically same thing you can get on some store shelves, just throw away the 55w bulbs).
    It's a must to do relay power to these lights, but definitely worth it. I personally did it for "deer finding" a 1/4mi. down the road, so the deer last until morning for us hunters.
    We've installed them on 2 cars with HID's (roommate's 4300k & my 5000k), and you'll crap yourself when you click them on "over top of the HID beams".
    I pulled my HID's a while back, since they were OK, but too finicky even with 10ga relay power. The spray wasn't something I liked either, but overall it wasn't something I wanted to 100% remove. They may go back in, but I am leaning towards projectors with strong halogens in the distant future.
    If there's such a thing as "too bright," these might fit the profile, though. I run them in the daytime just like OEM ones with DRL disabled, since it doesn't affect oncoming unless they're directly ahead (turning, parkinglot...). At night, the difference between regular headlights and hibeams is minimal, but the 100w fogs come on with either (SCACGP jumper) and light up everything.
    - Dave
  5. #5 Re: How NOT to melt your fog lights
    Nov 2008
    Chicago
    That's exactly what I did on my Z. I bought a pair of $15 fog lights from harbor frieght and threw in some 100w bulbs as soon as the original bulbs went out. Man what a difference! Only problem is it cracked the glass on the el cheapo's in the winter. Thanks for the info!
  6. #6 Re: How NOT to melt your fog lights
    Nov 2008
    Chicago
    Does anyone know where to get 55w 898 fog light bulbs?
    If not, I'll be soldering some butt connectors on the original base and putting a higher wattage bulb in it
  7. #7 Re: How NOT to melt your fog lights
    Feb 2008
    Quote Originally Posted by FuglyGTP View Post
    Auto Zone, in the ricer aisle.
    I was looking at these too, But was wondering if they were really brighter, how much heat do they produce, and is our system able to handle the power load of a 55w increase from the stock 27w.
  8. #8 Re: How NOT to melt your fog lights
    Nov 2008
    Chicago
    Quote Originally Posted by Blown97 View Post
    SWEET!!! Thanks Blown! I'm sure they're brighter but by how much I do not know. Hopefully it says how many lumens it puts out on the back of the aftermarket bulb package.
    I'm not too worried about blowing anything up or melting anything with the 55w bulbs. Let's assume that the voltage of the car is 13.8. Here's the math:
    Stock
    27w / 13.8v = 1.956521739130435 amps per bulb
    Aftermarket
    55w / 13.8v = 3.985507246376812 amps per bulb
    So with stock bulbs we are drawing roughly 4 amps. With 55w bulbs we are drawing roughly 8 amps total. I would assume that there is a 10 amp fuse. If the wiring wasnt able to handle 10 amps, then the fuse could be useless in the event of an overloaded circuit.
  9. #9 Re: How NOT to melt your fog lights
    Feb 2008
    They don't unfortunately, this subject has got my interest....let me know how they go!!
  10. #10 Re: How NOT to melt your fog lights
    SE Level Member BigG's Avatar
    St. Louis
    I went from the stock 880/27watt bulb, to a 889/37watt bulb, an it melted my plastic fog light housing. It didn't destroy the housing, just melted it enough, that the fog light bulb was loose in the housing, an no longer aimed even close to correctly. FWIW. So, BlazerTechs, waiting to go in.
  11. #11 Re: How NOT to melt your fog lights
    Banned
    May 2008
    Not recommended to put upgraded lights on the stock wiring (the basic bulbs burn out all the time as it is, due to the crap setup)... BnB has a simple diagram to help you do the inexpensive upgrading in a matter of about 1hr: Fog Lamp Wiring Upgrade
    As long as the upgraded power wires (positive thru relay & ground to bulb) are thick enough, at least 12ga, you'll be able to run 55 or 100... 130 may be OK as well, but I'll probably swap my 12ga out for 8-10 and try going up from my 100's for kicks if one burns out.
    - Dave
  12. #12 Re: How NOT to melt your fog lights
    Nov 2008
    Chicago
    They melted with only a 10w upgrade? man that blows... so much for that idea
  13. #13 Re: How NOT to melt your fog lights
    Nov 2008
    Chicago
    I started searching for new foglights today. I found that this guy has 100w factory replacement bulbs if anyone wants to give this experiment a try eBay My World - xenonevil
  14. #14 Re: How NOT to melt your fog lights
    St. Louis
    UR LOSEN, made the definitive statement...."as everyone just upgrades to the HID kits" No bulb yu put in there, is going to be better than an HID kit.
  15. #15 Re: How NOT to melt your fog lights
    Banned
    May 2008
    And I've said that I'm probably the only one posting here who's had experience with both... and were installed at the same time on 2 separate GP's. Believe me, 100w fogs are no joke. Both cars I'm talking about, use HID's for regular beams, and the 100w fogs as "high's", if that says anything for you. ;-) (both have upgraded wiring for each harness)
    - Dave
  16. #16 Re: How NOT to melt your fog lights
    halogens are brighter than HIDs if you get high enough wattage bulbs. if you get the 100W or 130W bulbs it's going to be brighter than crap.
  1. Fog Lights
    By xbnb1978x in forum Visual/Body Modifications
    Last Post: 08-24-2008, 02:54 PM
  2. cop lights
    By Tyler_06 in forum Visual/Body Modifications
    Last Post: 07-04-2008, 05:05 PM
  3. ABS and TCS Off lights are on
    By 03GTPFour in forum General Tech Discussion
    Last Post: 04-23-2008, 10:10 AM
  4. what cause the lights ?
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-31-2008, 05:23 PM
