Thread: Low Coolant light
Results 1 to 5 of 5
  1. #1 Low Coolant light
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    What does it mean?
    No but seriously, My low coolant light is coming on and i'm not quite sure what the problem is. I converted my car from a 98 coolant bottle to a 99+ a couple weeks ago. Everything went smoothly but now the light is on. the reservoir is filled to the correct level and when the car is cool and i take the radiator cap off that seems full. After driving the car for 5 minutes or so the light goes off. Could I just have an air bubble in the system somewhere that's throwing the light?
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  2. #2 Re: Low Coolant light
    Ohio
    The sensor is dirty. Just unplug it so it doesn't come on anymore.
    The sensor is on the radiator tank by the battery (passenger side)
  3. #3 Re: Low Coolant light
    Buffalo, NY
    Is there a way to clean it or just permanetly leave it unplugged?
  4. #4 Re: Low Coolant light
    Ohio
    You can pull it out and clean it, but if you can check your coolant level once in awhile, then leave it unplugged
  5. #5 Re: Low Coolant light
    Buffalo, NY
    awesome thanks. Right after i made this thread i saw there was another one with basically the same info in the general GP talk section. dang.
  1. Coolant reservoir has brown junk in it and low coolant light flashing. what is it?
    By JessicaRebel in forum General Grand Prix Discussion
    Last Post: 09-15-2014, 08:37 AM
  2. Low Coolant Light
    By rvnwlf in forum General Tech Discussion
    Last Post: 07-14-2013, 06:00 PM
  3. Flashing Low Coolant Light, Coolant Full, No leaks
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2012, 08:25 PM
  4. low coolant light...but not so much low coolant..?..
    By 1lilcountrygrl in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
  5. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
