Thread: Transmission issue
Results 1 to 6 of 6
  1. #1 Transmission issue
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    Hello, 3 times in the last 2 weeks this has happened. Ill be sitting at a red light, then when it comes time to go, i press on the gas, the engine revs but the car barely moves, then about 1/2 a second to 1 second later youll feel it jerk (grab) then the car takes off and everything is normal. Whats goin on here? The fluid is full. I changed the fluid for the first time at 75000 miles, and have changed it every 25000 miles since then. When i say i "changed" it, i mean i did 3 drain and fills over the course of a week. car has 146000 miles..
    should i start saving for a new transmission, or could it be something less severe?
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  2. #2 Re: Transmission issue
    That's called a bang start. It's typically the input piston and seal. Sometimes it's valve body.
    Its time to consider a JY or rebuild if you are going to keep the car.
  3. #3 Re: Transmission issue
    Nov 2008
    Fremont Nebraska
    well shoot. Considering my resources, and recent shoulder surgery, the junkyard is not an option. About what should i expect to pay for a rebuild? i understand different areas will have different prices, but in general. $1000? $2000?
  4. #4 Re: Transmission issue
    get one of these shipped to your work or home. http://www.tripleedgeperformance.com..._to_Basix.html then have a local shop install it, all in all should be about 2000.00 with the labor unless you have a shop you trust.
  5. #5 Re: Transmission issue
    I'd say shop around for price/trustworthy.
  6. #6 Re: Transmission issue
    Aug 2011
    'Merica
    If you order the Back To Basix from TEP. There is around a month wait time for one, at least in my case. I have one on order.
  1. transmission or another issue ?
    By joshv in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-25-2013, 10:33 PM
  2. Transmission issue
    By BigRam2003 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-06-2013, 06:06 PM
  3. Transmission Issue
    By ao482 in forum Introductions/Noob Questions
    Last Post: 04-09-2013, 07:02 AM
  4. Transmission issue??
    By xsvtank in forum General Tech Discussion
    Last Post: 11-11-2010, 09:29 PM
  5. Possible transmission issue
    By Kurt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-18-2009, 02:02 PM
