Thread: Speed Daddy Headers or...?
Results 21 to 40 of 41
  1. #21 Re: Speed Daddy Headers or...?
    04 Comp G.
  2. #22 Re: Speed Daddy Headers or...?
    GTX Level Member blackflag's Avatar
    Virginia
    dont have to worry about that with sd's!
  3. #23 Re: Speed Daddy Headers or...?
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    I'm running SD headers on my car. Had them for 6 months, about 2500 miles. LOVE EM!! No silicone used, but get good band clamps for both the cross over and DP (or if you have your DP welded with the race pipe or cat no need for the 3" clamps). I have one leak, where the flange is at my DP but that's cause I used the cheap gasket that came with the kit. I'd use all your stock gaskets.
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  4. #24 Re: Speed Daddy Headers or...?
    GT Level Member hammerline81's Avatar
    Apr 2013
    Saskatoon, SK
    Well, that piece that sticks out would need to be straightened out a little, not because I'm lowering my car, but because of the driving conditions. I'll probably buy these bad boys and I guess I'll have a project on my hands for a bit. I've got a metal bandsaw, mig welders, even a lathe at my farm so I'm not short on any "tools" to do this lol. These look better than the painted headers anyways lol. In one forum this guy mentioned that the front o2 was pushed right against the firewall. Anyone have this problem? I've been searching the hell out of people's reviews before I asked any questions.
  5. #25 Speed Daddy Headers or...?
    Yay!
    -Most don't have a issue w/ the front o2 hitting the firewall but some do easy and simple fix...bash in the firewall a bit.
    -the metal fan shroud on fan hit the headers on mine...easy solution... Remove it.
    -AC line needs to be bent down a bit...easy fix... Take a rag and apply some pressure down slowly.
    -you need a o2 extension for the rear o2z
    -it comes with a test pipe so you have to decide if that's fine or if your going to add a cat...google spark plug fouler trip your probably gonna need this trick (I did)
    -flip your motor mounts or go with some poly ones.
    -some guys flip the sway bar to give you a little more room
    -purchase 2 2.25" band clamps and 2 3" band clamps unless you weld a bit
    -reuse stock gasket unless they're in bad conditions then Felpro will do.
    That should answer any potential problems you chould run into.
    04 Comp G.
  6. #26 Re: Speed Daddy Headers or...?
    Apr 2013
    Saskatoon, SK
    What kind of spark plug non-fouler did you pick up? I've never heard of that to trip the o2. I only knew about deleting it from the PCM or getting a simulator? I don't really like cats and mine are plugged, so I won't be running one. How big of a job is it to flip the mounts?
  7. #27 Speed Daddy Headers or...?
    04 Comp G.
  8. #28 Re: Speed Daddy Headers or...?
    Apr 2013
    Saskatoon, SK
    Right on! Well I won't be telling the old lady what I'm buying until it shows up, lol!! I'll probably be showing you guys what I've done and how I did it so either you can laugh at me or tell me I'm awesome.
  9. #29 Re: Speed Daddy Headers or...?
    gardner,mass
    Just a couple things from somebody who has sds and regrets not doing things befor i put them in.
    Weld in a new flex and fix the ubend. You will scrape and you will probly want to eventually lower the car and wont be able to untill you fix them and its easier befor you put them in then taking the rear header out later.
    Get quality clamps. I got the
    http://www.frozenboost.com/product_i...658635a74f8f8a
    But i kind of regret them and wish i would of went with something like these.
    http://www.jegs.com/i/JEGS-Performan...d=#moreDetails
    But the first mentioned will work, i just had to redo my crossover because i had a small leak.
    Use copper rtv, because its easier then fixing a leak once they are together.
    And spark plug non fouler trick. Very simple and cheap. http://shop.advanceautoparts.com/web...lug+non+fouler
    Drill out the center of one with a 1/2 inch drill bit, screw that one into the other and put the rear o2 in them. If you dont you will be wasting alot of gas.
    Oh forgot to mention when installing you will need to drop the rear cradle bolts a couple inches to get the rear header in. Other that that its a pretty straight foward install.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  10. #30 Re: Speed Daddy Headers or...?
    GT Level Member orange57's Avatar
    Aug 2012
    Chandler, AZ
    I'm thinking that I'm also going to pick up a set of these headers too. I've seen some of them that list they are for 97-03, will they fit the 04+ too? I thought I've read that it is all compatible.
    matt
    2004 Grand Prix GTP - work in progress
  11. #31 Re: Speed Daddy Headers or...?
    Apr 2013
    Saskatoon, SK
    Quote Originally Posted by orange57 View Post
    Thats why I kind of asked about the L32, but it'll fit. Maybe a little different than the earlier models but it should. I'm assuming REDCOMG has a 04+ Based on his pic. So just read through this forum and listen to these guys.
  12. #32 Re: Speed Daddy Headers or...?
    Apr 2013
    Saskatoon, SK
    Quote Originally Posted by Ginseng View Post
    I'll order the flex pipe from ZZP, theirs seem to be okay considering they put it on all their DP's. SD's flex pipe is a 3" right? Those jegs clamps were the ones I was thinking of in the first place, we use the big bastards on our semis and never fail. Is this the same as what your talking about? Description says it's a plug and play kinda thing.
    http://m.ebay.ca/itm/231049044965?nav=SEARCH&sbk=1
  13. #33 Re: Speed Daddy Headers or...?
    gardner,mass
    Quote Originally Posted by hammerline81 View Post
    Yes the headers have a 3 inch downpipe.
    That is 5 bucks at advanced like i showed you.
  14. #34 Re: Speed Daddy Headers or...?
    Apr 2013
    Saskatoon, SK
    Thanks for the help. I'll be buying these headers soon. It'll be a winter project for me cause I'm a farmer. Been working 14-17 hour days straight. Lol
  15. #35 Re: Speed Daddy Headers or...?
    Apr 2011
    Vassar, Mi
    I have 30k on my SD's. stock SD flex, felpro head-to-header gaskets, upgraded clamps, used the vband "u bend" and catback adapter that came with them, no RTV on any joints. No leaks anywhere on the system. I did have to hammer some clearance on the firewall for the o2 sensor, turned the code off with my DHP so no CEL. Extended the wires myself with some wire, solder, shrink wrap. Haven't ever heard the u bend scrape but there is a few marks on it. Wish I would have wrapped them though. On vacation in Tulsa, Ok when it was 107* out sitting in traffic the car wouldn't maintain temp with both fans on full blast. I partially blame this on my headers and all the extra underhood heat. Have never had a problem up here in MI though. It's only over 95* a few times a year.
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  16. #36 Re: Speed Daddy Headers or...?
    Apr 2013
    Saskatoon, SK
    Thats good to hear that its been holding up pretty well for 30k. i just ordered everything like 5 minutes ago so theres no turning back now. i have everything ordered except for the o2 trip, but thatll be on its way shortly. here comes my next project!! lol
  17. #37 Re: Speed Daddy Headers or...?
    Apr 2013
    Saskatoon, SK
    All I have to say is that job was a *****! and a note to anyone doing this job is to WATCH OUT FOR THE VACUUM MANIFOLD, second time I've snapped that little piece of **** working on this car...
  18. #38 Re: Speed Daddy Headers or...?
    Jul 2017
    NE
    Did the SD headers you put on fit? Their websites says they won't fit the 04 cars
  19. #39 Re: Speed Daddy Headers or...?
    they fit just fine on 04 up cars. nothing changed for them to not bolt up.
  20. #40 Re: Speed Daddy Headers or...?
    Kemmerer, Wyoming
    I have 04 supercharged heads on my 2001 with sd headers and they fit just fine, have fit fine for several years now.
  1. Looking for Speed Daddy Headers - '98
    By NinetyEightGTP in forum Wanted To Buy - Parts
    Last Post: 03-27-2013, 09:07 PM
  2. speed daddy headers
    By redlinepontiac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-16-2011, 07:54 PM
  3. speed daddy headers
    By sic40th in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2011, 05:07 PM
  4. Speed Daddy Headers
    By lflylow in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2010, 12:33 PM
  5. Speed Daddy Headers
    By Vioarr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2010, 03:29 PM
