Thread: Thinking of converting to E85.. Yes or Ne??
Results 1 to 20 of 224
  1. #1 Re: Thinking of converting to E85.. Yes or Ne??
    Banned
    CT
    I told you why lol
    DH keep your yapper shut...
  2. #2 Re: Thinking of converting to E85.. Yes or Ne??
    GTX Level Member crbquist's Avatar
    Massachusetts
    I meant I knew it was a pressure issue just didn't know where. Well, I emailed PRJ and he said to check the hose connection in my fuel pump to make sure it is tight enough. I pulled the pump this afternoon and discovered that the module hose was not fully connected to the top of the canister. There was about a 1 cm gap. Let's just say problem solved! My AFR is now at about an 11.7 max at shift point (6200rpm), and I no longer have hard starts. The pump was bleeding off pressure.
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  1. converting
    By cmn36 in forum General Tech Discussion
    Last Post: 01-15-2011, 07:18 PM
  2. converting a 01 to an 04
    By sasquatch094 in forum General Tech Discussion
    Last Post: 03-25-2010, 05:22 PM
  3. Converting to supercharged
    By Bechtel88 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2010, 09:31 AM
  4. question on converting.
    By gt42lst in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-12-2009, 11:54 AM
  5. Converting from a 1 bar to a 2 bar map.
    By TurboKent in forum General Tech Discussion
    Last Post: 03-16-2008, 02:10 PM
