Thread: Needing fully comprehensive schematics on ignition, BTSI, and neutral safety switch
Results 1 to 4 of 4
  1. #1 Needing fully comprehensive schematics on ignition, BTSI, and neutral safety switch
    SE Level Member BigBadjohn's Avatar
    Dec 2010
    So IL
    I need a good set of prints on the ignition switch, BTSI assembly, and neutral safety switch on the transmission and how they all tie in together. I have had to shift my transmission back and forth and/or jiggle the shifter button to get my key out for over 2 years now. But more recently, my automatic headlights, automatic speedometer lighting, my fuel mileage screen, and climate control blower have quit while driving down the road and also after first starting the car for the first couple of minutes. I very well could have 2 separate problems since I let the first problem go on for so long. I am an electrician and have a good strong understanding of controls yet I am not too familiar with a system like this in a car nor do I have a good set of prints (My Haynes manual sucks) and without those, you can't expect to fix it properly very easily
    My car is a 2002 Grand Prix GTP 40th anniversary edition 4-door
    If anyone has any prints, I would be greatly appreciative. All I can seem to find online are idiots showing others how to disable the interlock as if that were an acceptable repair (if you can even call it a repair, more like a hacking up of the OEM harness)
    Thanks again
    John
    2002 Grand Prix GTP 40th anniversary sedan
  2. #2 Re: Needing fully comprehensive schematics on ignition, BTSI, and neutral safety swit
    Dec 2012
    Where 4T65E's were born
    Sold.
  3. #3 Re: Needing fully comprehensive schematics on ignition, BTSI, and neutral safety swit
    Dec 2010
    So IL
    Thankyou!
    Is there any more material that could be of use to me?
  4. #4 Re: Needing fully comprehensive schematics on ignition, BTSI, and neutral safety swit
    Dec 2010
    So IL
    Heres another schematic I found on GPONA and its a little different. It shows a park switch in the BTSI/center console that I don't see on your schematic above. Is there a park position switch in the console?
    http://www.gpona.com/forums/post435302.html#p435302
  1. Neutral Safety switch harness
    By kissmyss in forum Off Topic Discussion
    Last Post: 11-11-2010, 03:09 PM
  2. Neutral Safety Switch replaced---Still problems
    By jokyfo in forum General Tech Discussion
    Last Post: 03-27-2009, 09:06 AM
  3. Neutral Safety Switch
    By Roadzombie in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-28-2008, 09:39 PM
