Thread: Top Front Motor Mount
Results 1 to 10 of 10
eetchickn Top Front Motor Mount 08-22-2013, 06:14 PM
02NavyBlue Re: Top Front Motor Mount 08-22-2013, 06:51 PM
Scottydoggs Re: Top Front Motor Mount 08-22-2013, 07:22 PM
Frosty Re: Top Front Motor Mount 08-27-2013, 08:16 PM
eetchickn Re: Top Front Motor Mount 09-26-2013, 04:05 PM
Scottydoggs Re: Top Front Motor Mount 09-26-2013, 04:20 PM
eetchickn Re: Top Front Motor Mount 09-28-2013, 12:52 PM
eetchickn Re: Top Front Motor Mount 09-28-2013, 06:09 PM
Scottydoggs Re: Top Front Motor Mount 09-28-2013, 06:39 PM
eetchickn Re: Top Front Motor Mount 09-28-2013, 06:50 PM
  1. #1 Top Front Motor Mount
    Jul 2013
    Richmond, VA
    I just discovered that the cast piece that the passenger side (front) torque mount is bolted to is broken. Everywhere I look I can find the strut and the radiator core side, but not the cast piece that bolts to the engine (the engine side of the dogbone). Can someone please post a part number or the actual name of the part?
  2. #2 Re: Top Front Motor Mount
    Dec 2012
    Where 4T65E's were born
    I remember someone asking about this in another post. That part usually breaks due to overtightening/stress. I can't remember what the final decision was but most were suggesting to go to a junkyard.
    I'll try to find the post and edit this if I do. Not likely since the GP forums search is pretty spotty.
    http://www.grandprixforums.net/found...unt-32026.html
    http://www.grandprixforums.net/cracked-upper-motor-mount-bracket-32719.html
    http://www.grandprixforums.net/broke...unt-54425.html
    I couldn't find the one I was looking for, but found these equally relevant topics.
    Sold.
  3. #3 Re: Top Front Motor Mount
    find and use a l67 coil mount/dog bone mount, they dont break.
  4. #4 Re: Top Front Motor Mount
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    I agree with this. They weigh like 30 pounds it seems like as well.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  5. #5 Re: Top Front Motor Mount
    Jul 2013
    Richmond, VA
    Alright so I found an l67 bracket from a kind soul on this forum. No bolts though. Will the bolts from the broken bracket transfer over to the l67 mount? I assume the bolt for the dogbone will transfer, its the bolts holding the bracket to the engine block that concerns me.
    If the bolts do not transfer over, what size bolt would I need to purchase?
  6. #6 Re: Top Front Motor Mount
    its been a while since i had mine off, but i recall the sc engine has a threaded shaft on the side where the sc tentioner gets bolted on, then theres was 2 more bolts that held it on the side of the head.
    not sure how your old coil bracket was bolted on, as i dont have a n/a in my car. but i know this swap has been done countless times. should be as easy as bolting it on there.
  7. #7 Re: Top Front Motor Mount
    Jul 2013
    Richmond, VA
    Unfortunately the coil mount does not even come close to fitting on the l67 mount. This could get interesting. Anybody done this before? Is there another part I need to get to make this work?
  8. #8 Re: Top Front Motor Mount
    Jul 2013
    Richmond, VA
    Alright just to close the loop, there are threaded shafts on the NA too. The part that gets fun is getting the pad (the aluminum electronic thing the coils plug in to) attached to the l67 bracket. None of the holes line up. So what I did is I took a hack saw to the NA coil mount and cut the fins and bolt holes off the bottom. If you hold the coil pad on the modified NA mount there is one spot where you can bolt through both. I marked where that is on the l67 bracket, drilled and tapped a new hole then bolted everything together. If you wonder why I went the extra step of modifying the old mount, seems if was also acting as a heat sink and I was afraid leaving that out would burn up my coils.
    Once the new bracket is in place on the engine, you will need to shoehorn the battery back in using a crowbar so be ready for that.
  9. #9 Re: Top Front Motor Mount
    why a pry bar to get the battery back in? did you not move the cross brace?
    i take the 2 lower bolts out, then loosen the upper one, slide it to the side. or just take it off. then theres nothing in the way.
  10. #10 Re: Top Front Motor Mount
    Jul 2013
    Richmond, VA
    I had the cross brace off, clearance problem was between the coil pack and the slanted part of the front clip. The previous owner may have put a larger battery in there though.
  1. How to change lower motor mount and trans mount
    By AlanP in forum How To Write-Ups/Tech Tips
    Last Post: 01-10-2021, 12:39 AM
  2. Front Motor Mount DIY-able?
    By Kolton Lock in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-19-2012, 02:47 PM
  3. '98 3.1L lower motor mount, tranny mount replacement help
    By Patrick551 in forum General Tech Discussion
    Last Post: 10-07-2012, 11:37 PM
  4. The motor Mount on the passenger side of the motor.
    By Nuzzget in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-30-2009, 09:27 PM
  5. Front Motor Mount Brackets..
    By GP2003GT in forum Visual/Body Modifications
    Last Post: 03-31-2008, 11:31 AM
