Thread: P0128 Different issue
Results 1 to 8 of 8
  1. #1 P0128 Different issue
    SE Level Member AlanP's Avatar
    Dec 2012
    Fair Haven, NJ
    Hey all. I've been searching around but can't find the same issue P0128 I'm having:
    When the weather cools I start throwing a P0128 code. It happens when I first start the car, not after 10 minutes of running. Car runs fine the entire time. I have a 180T non-drilled and have replaced it with another 180T non-drilled, reset the code, and it still comes back on. Suggestions?
  2. #2 Re: P0128 Different issue
    Temp sensor gunked up?
  3. #3 Re: P0128 Different issue
    put the 195 back in?
    have you changed the temp sensor or checked the wires leading to it? its got a short harness too, so 2 plugs to check and clean.
  4. #4 Re: P0128 Different issue
    Dec 2012
    Fair Haven, NJ
    Never heard of that. Wouldn't it be in the radiator?
  5. #5 Re: P0128 Different issue
    Dec 2012
    Fair Haven, NJ
    Where would I locate the sensor?
  6. #6 Re: P0128 Different issue
    its under the t stat. in the bottom of the lim.
  7. #7 Re: P0128 Different issue
    Dec 2012
    Fair Haven, NJ
    I see it. Can I pull it out without draining the fluid??
  8. #8 Re: P0128 Different issue
    theres one in the rad too, but its the low coolant sensor.
    look under the lim under the t stat, its there.
  1. P0128 code
    By TDgrand in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-24-2013, 09:33 PM
  2. P0128
    By anarchy in forum General Grand Prix Discussion
    Last Post: 08-16-2012, 08:49 AM
  3. Getting P0128 code in the summer
    By picghaw in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-26-2011, 11:42 PM
  4. p0128
    By fremmy182 in forum General Tech Discussion
    Last Post: 11-26-2010, 12:06 PM
  5. Code P0128
    By trenaro in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-28-2010, 08:38 PM
