Thread: Radio,dic,hvac all inop
Results 1 to 11 of 11
  1. #1 Radio,dic,hvac all inop
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    odd problem, I'll try and explain as easily as possible.
    the DIC doesnt show display, but the side buttons all light up and blink intermittently
    the radio doesnt power on, but it does light up
    the HVAC is dual climate, and doesnt show display nor does it power up, but it also lights up.
    also the HUD fades in and out after about 10 minutes, is this the HUD module or switch??
    are these all on a related ground/relay/fuse?
    any help would be greatly appreciated
    thanks
    COMP G
  2. #2 Re: Radio,dic,hvac all inop
    Nov 2008
    Burkburnett, Texas
    I had the same problem it was a fuse under the hood I don't remember it right now. It has to do with your HVAC. For the HUD it is just module not the switch.
  3. #3 Re: Radio,dic,hvac all inop
    Oklahoma
    Im wondering if it might be the ignition switch, since most if not all the accessories run through there. But as theboss pointed out, it could be something simple like a fuse, so I would start there.
  4. #4 Re: Radio,dic,hvac all inop
    Apr 2008
    Vallejo,Ca
    i checked the dash fuses, the fuses were good, i have not checked under the hood yet, it figures about the HUD though, i just sold my good one lol. i just thought it was odd that all three systems (radio,DIC,HVAC) are out. just bought this car 2 days ago 1998 daytona pace car. I'll get back to you. i will check under hood today any other ideas?
    COMP G
  5. #5 Re: Radio,dic,hvac all inop
    Apr 2008
    Vallejo,Ca
    ok, turns out Boss you were correct , the radio battery fuse (10 amp) was popped under the hood. replaced the fuse and i have the DIC,HVAC, and radio again, now the hvac isnt blowing. thanks for the help
    COMP G
  6. #6 Re: Radio,dic,hvac all inop
    Oklahoma
    Isnt blowing in that the motor isnt working at all? Ive heard of a few having to replace the motor, but there should also be a fuse for that as well. Also, the blower motor resistor might be bad too.
  7. #7 Re: Radio,dic,hvac all inop
    Apr 2008
    Vallejo,Ca
    i turn it up full blast and nothing comes from the vents, no sound. i do have a band new blower motor resistor sitting in the box, it cant hurt to try that. the fuses for hvac are good. sucks though that i just sold my blower motor now i cant even try it to see lol.
    COMP G
  8. #8 Re: Radio,dic,hvac all inop
    Nov 2008
    Burkburnett, Texas
    That's good you found out I am glad I could help.
  9. #9 Re: Radio,dic,hvac all inop
    Apr 2008
    Vallejo,Ca
    as far as remember now, the blower resistor controls speeds 1-4 and the 5 ( high speed) was on a fuse. that was for the 3 knob HVAC control.
    i have the dual climate HVAC now and im assuming the resistor would be the same. and i have no blow at any speed
    COMP G
  10. #10 Re: Radio,dic,hvac all inop
    Oklahoma
    I think you may be correct as I ran without the high (5) speed for a very long time, then the others went out due to the ignition switch so I just replaced the switch and the resistor and got everything back to normal.
  11. #11 Re: Radio,dic,hvac all inop
    Apr 2008
    Vallejo,Ca
    ok, now it blows but very low, like on full blast if i put my hand about 2-3 inches from the vents i can feel air, but when even at full blast with the vents facing me it doesnt reach me at all. its probably nothing cause i could feel the air through the vents at 80 mph ;p
    COMP G
  1. HVAC help
    By 3800SE in forum General Tech Discussion
    Last Post: 03-07-2010, 07:02 PM
  2. Stock stereo backlight inop? Which speakers to replace stock?
    By Z28 in forum Audio, Security & Visual Electronics
    Last Post: 12-04-2008, 11:47 PM
  3. HVAC Blower Question
    By 2001camaroB4C in forum General Tech Discussion
    Last Post: 10-25-2008, 02:05 AM
  4. No hvac control
    By Onthebrinc in forum General Tech Discussion
    Last Post: 03-23-2008, 03:24 PM
  5. hvac control
    By Chleby in forum General Tech Discussion
    Last Post: 01-17-2008, 11:53 AM
