Thread: Multifaceted Question/Situation (Oil Pan Gasket, Shift-Kit, False Knock, et. al)
Results 1 to 20 of 26
  1. #1 Re: Multifaceted Question/Situation (Oil Pan Gasket, Shift-Kit, False Knock, et. al)
    Flip the swap bar if you havent, under a heavy load the downpipe on the headers can smack/rub the sway bar and give false KR.
  2. #2 Re: Multifaceted Question/Situation (Oil Pan Gasket, Shift-Kit, False Knock, et. al)
    GT Level Member bsharpminor's Avatar
    Mar 2012
    Minnesota
    Thanks
  3. #3 Re: Multifaceted Question/Situation (Oil Pan Gasket, Shift-Kit, False Knock, et. al)
    Mar 2012
    Minnesota
    I forgot to mention that I've modified the down pipe on my sd's. There should be a fair amount of clearance, but I'll be sure to take a look at it when I get the car up in the air this weekend.
    Anybody else have any other ideas of things that could be causing my false kr?
  1. False knock causing p0327?
    By outonthetiles in forum General Tech Discussion
    Last Post: 05-18-2012, 03:16 PM
  2. False knock??
    By dsmuts in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-23-2011, 04:43 PM
  3. False Knock?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-06-2011, 11:14 PM
  4. false knock?
    Last Post: 08-20-2009, 09:21 PM
  5. new gasket less knock...?
    Last Post: 08-20-2009, 10:04 AM
